Discuss
Refrigerator Clicking Noise
 in
Refrigerator & Freezer Repair
There is no diagnostic test for the board. In your case, the only recourse is to assume the new board
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrigerator Clicking Noise
  #21 (permalink)
Old 03-15-2012, 01:24 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
There is no diagnostic test for the board. In your case, the only recourse is to assume the new board is bad unless your damper door jamed closed.
Ads By Google
__________________
  #22 (permalink)
Old 03-15-2012, 02:12 AM
Junior Member
KULTULZ is on a distinguished road
Thumbs up
Quote:
So the best plan of attack is to remove the damper asm and check for damper jam before rattling the vendors' cage that sold me the board?
Is there a current check to verify the damper motor is good before or once removed?
Something wrong @ the damper seems to make sense. Either jammed or not receiving signal current.
AGAIN THANX!
  #23 (permalink)
Old 03-15-2012, 02:17 AM
Junior Member
salmanblc is on a distinguished road
Default Do you have Guarantee or Warranty for it?
If you have Warranty thn call Support. otherwise, do read Manual Book for Whcih Part is Clicking Type if not working..
__________________
Backlinks-Cafe.com Affordable SEO Services.
  #24 (permalink)
Old 03-15-2012, 01:21 PM
Senior Expert
APP Volunteer
Default
The motors on these rarely fail. Open the fridg door and the freezer door. Push the fridg light switch closed and check for light from the damper. If no light, remove the cover and see if the damper door is jamed shut or blocked by ice. Manually open the door, if it closes, and you hear the damper motor run, you either have a bad damper thermistor or a bad board.
__________________
  #25 (permalink)
Old 03-15-2012, 02:30 PM
Junior Member
Red face Getting Brave
OK.
I completely removed the Damper Asm, not knowing what light to look for. I now realize the freezer compartment light via the cooling chute. The damper door is open (vertical position?). I then reinstalled the Asm and powered her up...
It was blowing cold air up through the chute opening (top of freezer compt). I then got really brave and plugged the Damper Motor connector back into the harness. No door movement. There is cooled air now being forced through the Damper Asm air outlets. There seems to be a small volume.
I have left it in stealth mode to see if the temp(s) drop in either or both compartments. I will report back.
I really appreciate your patience as it would be a B*T*C* to have to call in a repair person at this stage.
Is it possible that the evaporator is dust bound leading to a low forced air situation?
  #26 (permalink)
Old 03-15-2012, 03:58 PM
Senior Expert
APP Volunteer
Default
Seems like your evaporator is frozen, just remove the freezer back panel and verify frost pattern, probably all covered with heavy frost.
__________________
  #27 (permalink)
Old 03-16-2012, 06:17 AM
Junior Member
Talking
I allowed the refrig to run and the temp(s) finally stabilized by morning. It has to be divine intervention...
Could it be the first go-around resulted in a frozen evaporator and the unplugging allowed it to defrost itself? Could there be a problem with the actual defrost system that I should monitor? The damper door is functional. It closed when box temp came close to temp setting.
Again, much thanks for your expertise.
  #28 (permalink)
Old 03-16-2012, 01:45 PM
Senior Expert
APP Volunteer
Default
I would monitor the freezer temperture to confirm good refrigeration.Freezer should get near 5 to 10 degrees.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator will make clicking noise after Door is opened james114203 Refrigerator & Freezer Repair 0 11-07-2011 08:56 AM
Buzzing and Clicking noise. refrigerator stopped working DavidJo Refrigerator & Freezer Repair 4 07-17-2011 10:19 AM
GE Refrigerator making clicking noise and water dispenser only shoots short streams natratreid Refrigerator & Freezer Repair 0 06-23-2011 11:13 AM
Clicking noise when refrigerator cycles acerwf Refrigerator & Freezer Repair 3 05-21-2008 04:23 PM
GE Profile- Refrigerator not cool, and hear a clicking noise hfranke2 Refrigerator & Freezer Repair 2 04-11-2008 04:12 AM
