Discuss
Freezer is fine, refrigerator is too warm
 in
Refrigerator & Freezer Repair
My fridge temperature went up to 60 degrees, I removed the back panel and found the coil assembly mostly frozen.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer is fine, refrigerator is too warm
  #1 (permalink)
Old 12-21-2011, 09:42 PM
Junior Member
samsungtrouble is on a distinguished road
Default Freezer is fine, refrigerator is too warm
Model Number: rs2545sh   Brand: Samsung   Age: 5 - 10 years
I tested the fan and it works, after defrosting the assembly with a hair dryer, the frige temperature is back to normal to 32 degrees.
I'm afraid that the freezing will continue and the fridge temperature will go up again.
the fan does work when the door is closed
do you have a part# that you recommend replacing to avoid the freezing / warming up problem?
thank you
Ads By Google
Related Models
Maytag RS2545SH Ref - Sxs
Maytag RS2555BB Ref - Sxs
Maytag RS2555BB/XAA Ref - Sxs
Maytag RS2555SL Ref - Sxs
Maytag RS2555SL/XAA Ref - Sxs
Maytag RS2555SW Ref - Sxs
Maytag RS2556BB Ref - Sxs
Maytag RS2556BB/XAA Ref - Sxs
Maytag RS2556SH Ref - Sxs
Maytag RS2556SH/XAA Ref - Sxs
Maytag RS2556WW Ref - Sxs
Maytag RS2556WW/XAA Ref - Sxs
Maytag RS255BABB Ref - Sxs
Maytag RS255BASB Ref - Sxs
Maytag RS255BAWW Ref - Sxs
Maytag RS2577BB Ref - Sxs
Maytag RS2577BB/XAA Ref - Sxs
Maytag RS2577SL Ref - Sxs
Maytag RS2577SW Ref - Sxs
Maytag RS2577SW/XAA Ref - Sxs
Maytag RS2578BB Ref - Sxs
Maytag RS2578BB/XAA Ref - Sxs
Maytag RS2578SH Ref - Sxs
Maytag RS2578SH/XAA Ref - Sxs
Maytag RS2578WW Ref - Sxs
Maytag RS2578WW/XAA Ref - Sxs
Maytag RS257BARB Ref - Sxs
Frigidaire RS259ESD1 Wwh(v1) / Side By Side Refrigerator
Frigidaire RS259ESD2 Wwh(v2) / Side By Side Refrigerator
Frigidaire RS259ESF1 Wwh(v3) / Side By Side Refrigerator
Frigidaire RS259ESF2 Wwh(v4) / Side By Side Refrigerator
Frigidaire RS259ESH1 Wwh(v5) / Side By Side Refrigerator
Frigidaire RS259ESH2 Wwh(v6) / Side By Side Refrigerator
Frigidaire RS259ESV1 Wwh(v7) / Side By Side Refrigerator
Frigidaire RS259ESV2 Wwh(v8) / Side By Side Refrigerator
Frigidaire RS259ESW1 Wwh(v9) / Side By Side Refrigerator
Frigidaire RS259ESW2 Wwh(v10) / Side By Side Refrigerator
Whirlpool RS25AEXLQ00 Refrigerator
Whirlpool RS25AFXMQ00 Refrigerator
Whirlpool RS25AFXRD01 Refrigerator
Whirlpool RS25AFXRD02 Refrigerator
Whirlpool RS25AGXNQ00 Refrigerator
Whirlpool RS25AGXNQ01 Refrigerator
Whirlpool RS25AGXNQ02 Refrigerator
Whirlpool RS25AQXFN00
Whirlpool RS25AQXFN01
Whirlpool RS25AQXFN02
Whirlpool RS25AQXFW00
Whirlpool RS25AQXFW01
Whirlpool RS25AQXFW02
Whirlpool RS25AQXGN00
Whirlpool RS25AQXGN01
Whirlpool RS25AQXGN02
Whirlpool RS25AQXGW00
Whirlpool RS25AQXGW01
Whirlpool RS25AQXGW02
Whirlpool RS25AWXAL00
Whirlpool RS25AWXAW00
Whirlpool RS25AWXBL00
Whirlpool RS25AWXBL01
Whirlpool RS25AWXBN01
Whirlpool RS25AWXBW00
Whirlpool RS25AWXBW01
Whirlpool RS25AWXDN00
Whirlpool RS25AWXDW00
Whirlpool RS25AWXEN00
Whirlpool RS25AWXEN01
Whirlpool RS25AWXEW00
Whirlpool RS25AWXEW01
Whirlpool RS25AWXVL00
Whirlpool RS25AWXVL02
Whirlpool RS25AWXVW00
Whirlpool RS25AWXVW02
Whirlpool RS25AWXWL00
Whirlpool RS25AWXWW00
Whirlpool RS25AWXXL00
Whirlpool RS25AWXXW00
Whirlpool RS25AWXZL00
Whirlpool RS25AWXZW00
Whirlpool RS25AWXZW01
Whirlpool RS25CFXTQ00 Refrigerator
Whirlpool RS25CFXTQ01 Refrigerator
Whirlpool RS25CGXTD00 Refrigerator
Maytag RS2621SW Ref - Sxs
Maytag RS2622SW Ref - Sxs
Maytag RS2622SW/XAA Ref - Sxs
Maytag RS2623BB Ref - Sxs
Maytag RS2623BB/XAA Ref - Sxs
Maytag RS2623SH Ref - Sxs
Maytag RS2623SH/XAA Ref - Sxs
Maytag RS2623SL Ref - Sxs
Maytag RS2623SL/XAA Ref - Sxs
Maytag RS2623VQ Ref - Sxs
Maytag RS2623VQ/XAA Ref - Sxs
Maytag RS2623WW Ref - Sxs
Maytag RS2623WW/XAA Ref - Sxs
Maytag RS2624WW/XAA Ref - Sxs
Maytag RS2630SH Ref - Sxs
Maytag RS2630SH/XAA Ref - Sxs
Maytag RS2630WW Ref - Sxs
Maytag RS2630WW/XAA Ref - Sxs
Maytag RS2644SL Ref - Sxs
Maytag RS2644SL/XAA Ref - Sxs
Maytag RS2644SW Ref - Sxs
Maytag RS2644SW/XAA Ref - Sxs
Maytag RS265LABP Ref - Sxs
Maytag RS265LAWP Ref - Sxs
Maytag RS2666SL Ref - Sxs
Maytag RS2666SW Ref - Sxs
Maytag RS2666SW/XAA Ref - Sxs
Maytag RS267LABP Ref - Sxs
Maytag RS267LABP/XAA Ref - Sxs
Maytag RS267LASH Ref - Sxs
Maytag RS267LASH/XAA Ref - Sxs
Maytag RS269LARS Ref - Sxs
Maytag RS2777SL Ref - Sxs
Hoover RS27D011 Ref - SXS/I&W
Amana RS30 Mwave - Cntrtp / Stand Alone
  #2 (permalink)
Old 12-22-2011, 12:37 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for Samsung RS2545SH REF - SXS | AppliancePartsPros.com
Here is a manual(SAM0093)
http://appliancejunk.com/forums/inde...=view;down=374
You will have to join the site to get the manual but it is free and is a good site for a DIYer.
Run the diagnostics and try to force a defrost cycle.
Check that the defrost heater comes on.
Be careful that you do not burn your fingers.
If the defrost heater does not come on.
Unplug the fridge and the heating coil and measure it with a meter.
If it is open (infinite ohms), it is toast.
Now here comes the twist you cannot buy just the heater Samsung wants you to replace the evaporator coil and the heater which turns this into an expensive repair as you will need a pro.
I would buy the evaporator assembly and try to remove the old heater and install the new one without replacing the evaporator coil.
With luck someone else will jump in with a better solution.
If the heater is OK check the thermistor.
If it is OK then odds are that the control board is toast.
PS: Samsung's are a pain in the you know what!!!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer is fine; refrigerator warm LaDonna357 Refrigerator & Freezer Repair 15 03-28-2012 04:55 AM
freezer fine refrigerator warm pdsullivan Refrigerator & Freezer Repair 0 10-26-2011 07:09 PM
freezer fine refrigerator warm gerefrigerator01 Refrigerator & Freezer Repair 1 09-20-2011 09:44 PM
Refrigerator too warm, freezer fine b3bilco Refrigerator & Freezer Repair 2 05-08-2010 11:15 AM
Freezer is fine, refrigerator is too warm. allemich Refrigerator & Freezer Repair 3 04-20-2009 07:08 PM
