Discuss
Freezer Problem
 in
Refrigerator & Freezer Repair
HELP!!!! My Standing Freezer has been turning off by itself and the low temperature warning light comes on. I reset
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer Problem
  #1 (permalink)
Old 12-21-2011, 12:11 AM
Junior Member
bluehawaii is on a distinguished road
Default Freezer Problem
Brand: Kenmore   Age: 5 - 10 years
HELP!!!! My Standing Freezer has been turning off by itself and the low temperature warning light comes on. I reset the warning and select quick freeze to get it to freeze again. After a few days it quits and trips off the circuit breaker.
When I reset the circuit breaker the freezer trips it again. Please what do I do. Do I need a new compressor?
  #2 (permalink)
Old 12-21-2011, 06:16 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number may help others help you.
I cannot be sure but it does not sound like a bad compressor.
A bad compressor would trip the breaker more often.
Does it cycle on/off?
Try plugging it into a different outlet.
Could be a bad circuit breaker.
I am assuming the breaker you are referring to is in the electrical box and that it is a standard breaker not a GFI.
Would be a big help if you could catch it when it trips the breaker as it may have something to do with the defrost cycle if the unit has this.
__________________
  #3 (permalink)
Old 12-21-2011, 04:56 PM
Junior Member
Default
Denman,thanks for your response.I tried to reset the main wall circuit (not GFI), and it causes the light in the room to blink and immeditely trips off the CB . I believe the CB is OK as well as the power outlet.
  #4 (permalink)
Old 12-22-2011, 02:22 AM
Senior Expert
APP Volunteer
Default
I would check the compressor and it's start device.
Here is a good link on how to do this.
How To Fix a Refrigerator - Appliance Repair Guide - ACME HOW TO.com
If the compressor has a fan check that it is running.
__________________
  #5 (permalink)
Old 12-23-2011, 07:32 PM
Junior Member
Default
Denman, when I plug in the freezer into the power outlet, it immediately trips the main wall circuit breaker. After about 9 attempts, I gave up.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fan problem in freezer sksmith Refrigerator & Freezer Repair 1 02-20-2010 08:53 AM
GE Freezer Problem cachr33 Refrigerator & Freezer Repair 0 10-07-2009 07:58 AM
Freezer Problem weilersbacher Refrigerator & Freezer Repair 2 04-11-2009 03:55 AM
Freezer problem sidavis Refrigerator & Freezer Repair 1 09-03-2008 12:33 PM
Freezer problem pmik33 Refrigerator & Freezer Repair 0 04-06-2008 06:45 PM
