Discuss
Whirlpool Refrigerator Always Running
 in
Refrigerator & Freezer Repair
Refrigerator always stays running at 3 and above, if I lower the thermostat to around 2, she seem to operate
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Whirlpool Refrigerator Always Running
  #1 (permalink)
Old 12-30-2007, 10:04 PM
Mark57 Mark57 is offline
Junior Member
Mark57 is on a distinguished road
Default Whirlpool Refrigerator Always Running
Model Number: ED22TQXFW00   Brand: Whirlpool   Age: 5 - 10 years
Refrigerator always stays running at 3 and above, if I lower the thermostat to around 2, she seem to operate ok.......Food and drink stays cold. The freezer seems to be ok. (Should I replace the thermostat?) This Whirlpool was made 12/1998
Thank you,
Mark
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-31-2007, 03:59 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Measure the back freezer wall temperature and post. If over 10-15 degrees pull off back freezer panel and describe evaporator coil frost.
__________________
  #3 (permalink)
Old 01-03-2008, 03:58 PM
Junior Member
Default
Hi Richappy,
Today purchased a thermometer, looks like my readings are good.....2 degrees when running and 15 degrees just before she turns back on. Now I placed the thermometer at the vent on the back wall of the freezer panel to get these readings.
Last night I noticed I had to turn down the thermostat between 1 and off on thew frig side to shut it off, was running a long time.
So what do you think whats my problem?
Thanks for your help,
Mark
  #4 (permalink)
Old 01-03-2008, 04:56 PM
Senior Expert
APP Volunteer
Default
You have marginal refrigeration, it is NOT your cold control. Pull the back freezer panel off and describe frost pattern, should be completely frosted over.For a fidge running a long time, freezer temp. should get down below zero.
Also clean your condensing coils in the back. Please post results.
__________________
  #5 (permalink)
Old 01-06-2008, 04:30 PM
Junior Member
Default
Today I cleaned the back of the condensing coils and all around the bottom. I removed the back freezer panel to noticed the evaporator, it was all Frosted up, before I removed the temp was at -6.
She still runs best at around 2 1/2 on the thermostat?????
  #6 (permalink)
Old 01-06-2008, 05:24 PM
Senior Expert
APP Volunteer
Default
You have a mechanical defrost timer in the fridg control panel, locate it and turn the middle knob clockwise with a flat bladed screwdriver till the compressor stops and the defrost heater starts heating. If so, you must replace the defrost timer, its probably stuck. If no defrost, you probably have a bad defrost thermostat, a little round thing clipped to the evaporator coil in freezer. You can defrost your coils with a hair dryer.
__________________
  #7 (permalink)
Old 01-07-2008, 02:27 PM
Junior Member
Default
On the defrost timer I made one complete turn and the compressor stopped. (I'll order the timer from this site.) Looks like it was defrosting, water was dripping down into the drip pan. Should I turn the defrost timer back a turn or leave as is? Oh and should I replace the defrost thermostat while I'm at it?
Richappy,
Thank you for your time and all your help.
Mark57
  #8 (permalink)
Old 01-07-2008, 02:46 PM
Senior Expert
APP Volunteer
Default
Yes, order a new defrost thermostat and turn your defrost timer to turn the compressor on, it might stick in defrost.
__________________
  #9 (permalink)
Old 01-09-2008, 08:49 PM
Junior Member
Default
Today install the new defrost timer, she ran for over 4 hr's was at -8 so I drop the cold thermostat from 3 to 2 1/2 until the compressor stopped.
Could this now be a cold control problem? (Thermostat)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator Running To Cold Eugene Refrigerator & Freezer Repair 6 11-13-2007 09:13 AM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 11:47 AM
Whirlpool dryer won't stop running dryrprob Dryer Repair 5 11-04-2007 03:38 AM
Refrigerator running but not cooling williamclydemoon Refrigerator & Freezer Repair 1 10-17-2007 04:13 AM
whirlpool refrigerator CHERYL ATCHLEY Refrigerator & Freezer Repair 4 10-14-2007 04:28 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
