lesgreenwood
#1 Posted : Monday, June 29, 2009 8:18:03 AM(UTC)
lesgreenwood
Hi there. I have a noisy fan on my fridge/freezer. When I open the fridge door the fan slows and then stops with quite a lot of noise. With the door closed, the fridge is still noisy, so I'm assuming it must be a fan connected to the fridge operation because it only shuts off when I open the fridge door.
Is it a fairly easy DIY replacement, or would I need an engineer to fix it?
Thanks, Les Greenwood
woodchuckie
#2 Posted : Monday, June 29, 2009 10:38:36 AM(UTC)
woodchuckie
It's the fan in the freezer behind the back cover.Evaporator fan. On some models the fan stops when the doors are opened.
Fan can be worn out or it could hitting something. It's not hard to replace.
Look for a complete model number for part location. Model Number Locator
