| » Refridgerator/Freezer, cold on the bottom NOT on the top |
Model Number: HSS25IFMC WW Brand: GE Age: 5 - 10 years
Hot Point, Side x Side. w/Ice and water in the door.
serial #SA208216 Both the Refirdgerator and Freezer are cold on the bottom and warm on the top. I have 2 problems with this unit. 1st - the solenoid for the ice/water dispenser is all rusted and needs to be replaced. (I have figured this problem out) 2nd - both the fridge and freezer are cold on the bottom and warm on the top. When i investigated the unit i found the coils behind the freezer panel to be iced up. I checked and made sure the drain was not plugged. The unit sounds like it is running. i do not hear what I would call a circulating fan. I believe this to be part number AP3191003 or AP3875639. I am not sure if this unit has a thermister. Am I on the right track? Do you have experience with this problem for this particlar unit. Please help. thank you, mmk Ads By Google Related Models |
check , defrost heater, defrost thermostat for defrost failure.
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com If the heater and thermostat are ok it’ll be the motherboard. Part 801 on diagram 10 is your motherboard. Replacement parts for GE HSS25IFMCWW | AppliancePartsPros.com The evaporator fan could be stopped by ice but it should be running when the compressor is. The fan also won't run when the unit is in the defrost cycle. It's behind the cover with the evaporator coils. |
| Display Modes | |
| Ge Profile, Refridgerator W/bottom Freezer | ncjbird | Refrigerator & Freezer Repair | 0 | 12-02-2009 02:07 PM |
| Amana Bottom Freezer Refridgerator Defrost Issue | RycherGirl | Refrigerator & Freezer Repair | 1 | 11-11-2009 02:38 AM |
| Kenmore w/ Freezer bottom drawer - Blowing Cold Air but not cold enough | tvGhouse | Refrigerator & Freezer Repair | 0 | 02-25-2009 02:50 PM |
| Freezer fine, refridgerator not getting cold enough | Eagle1ez | Refrigerator & Freezer Repair | 1 | 11-28-2008 08:37 AM |
| Refridgerator/freezer not getting cold | trying times | Refrigerator & Freezer Repair | 1 | 09-12-2008 05:41 PM |
