Discuss
Amana Ice Maker Funnel Freezing
 in
Refrigerator & Freezer Repair
MFG# PARS8265BS1 Two month ago I noticed ice sheets inside the door of my freezer. Water had been running down
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Amana Ice Maker Funnel Freezing
  #1 (permalink)
Old 12-16-2011, 02:41 PM
Junior Member
MiniDrivr is on a distinguished road
Question Amana Ice Maker Funnel Freezing
Model Number: ARS8265BS   Brand: Amana   Age: 5 - 10 years
MFG# PARS8265BS1
Two month ago I noticed ice sheets inside the door of my freezer. Water had been running down out of the ice bin, along one of the door panels and freezing there. I tracked down the leak to be from the funnel the water line drains into that feeds the ice maker. The funnel was solid full of ice. I de-iced it and monitored it closely for the next month. No ice in the funnel and it was functioning properly, making and dispensing ice as normal. Today again I find ice sheets and the funnel is solid with ice. Water flowing into the ice maker flows out of the funnel and into the ice storage below.
What's causing the ice to build up there? I've replaced the primary water valve twice since buying the frig due to leaks between the plastic housing of the valve and the metal fitting the water line connects to (line from the wall). Does the secondary valve control how much water it lets into the ice machine? If it's not shutting off at the proper time would it cause the ice in the funnel? It's never been replaced. I think it's part number AP4009555.
Thank you.
Related Models
Amana ARS8265BS REF - SXS/I&W
Amana ARS8265BW REF - SXS/I&W
Amana ARS8267BB REF - SXS/I&W
Amana ARS8267BC REF - SXS/I&W
Amana ARS8267BS REF - SXS/I&W
Amana ARS8267BW REF - SXS/I&W
Amana ARS9107AS REF - SXS/I&W
Amana ARS9107AW REF - SXS/I&W
Amana ARS9167AB REF - SXS/I&W
Amana ARS9167AC REF - SXS/I&W
Amana ARS9167AS REF - SXS/I&W
Amana ARS9167AW REF - SXS/I&W
Amana ARS9168AB REF - SXS/I&W
Amana ARS9168AC REF - SXS/I&W
Amana ARS9168AS REF - SXS/I&W
Amana ARS9168AW REF - SXS/I&W
Amana ARS9169AS REF - SXS/I&W
Amana ARS9265BB REF - SXS/I&W
Amana ARS9265BC REF - SXS/I&W
Amana ARS9265BW REF - SXS/I&W
Amana ARS9266BS REF - SXS/I&W
Amana ARS9268BB REF - SXS/I&W
Amana ARS9268BC REF - SXS/I&W
Amana ARS9268BW REF - SXS/I&W
Amana ARS9269BS REF - SXS/I&W
Amana ARSE664BB REF - SXS/I&W
Amana ARSE664BC REF - SXS/I&W
Amana ARSE664BS REF - SXS/I&W
Amana ARSE664BW REF - SXS/I&W
Amana ARSE665BB REF - SXS/I&W
Amana ARSE665BC REF - SXS/I&W
Amana ARSE665BS REF - SXS/I&W
Amana ARSE665BW REF - SXS/I&W
Amana ARSE667BB REF - SXS/I&W
Amana ARSE667BC REF - SXS/I&W
Amana ARSE667BS REF - SXS/I&W
Amana ARSE667BW REF - SXS/I&W
Amana ARSE66MBB REF - SXS/I&W
Amana ARSE66MBC REF - SXS/I&W
Amana ARSE66MBW REF - SXS/I&W
Amana ARSE66ZBB REF - SXS/I&W
Amana ARSE66ZBC REF - SXS/I&W
Amana ARSE66ZBS REF - SXS/I&W
Amana ARSE66ZBW REF - SXS/I&W
Amana ARSE67RBB REF - SXS/I&W
Amana ARSE67RBC REF - SXS/I&W
Amana ARSE67RBS REF - SXS/I&W
Amana ARSE67RBW REF - SXS/I&W
Amana ART1805BC REF - TOP MOUNT
Amana ART1805BW REF - TOP MOUNT
Amana ART2105BB REF - TOP MOUNT
Amana ART2105BC REF - TOP MOUNT
Amana ART2105BW REF - TOP MOUNT
Amana ART2107BB REF - TOP MOUNT
Amana ART2107BC REF - TOP MOUNT
Amana ART2107BS REF - TOP MOUNT
Amana ART2107BW REF - TOP MOUNT
Amana ART2127AB REF - TOP MOUNT
Amana ART2127AC REF - TOP MOUNT
Amana ART2127AS REF - TOP MOUNT
Amana ART2127AW REF - TOP MOUNT
Amana ART2129ABR REF - TOP MOUNT
Amana ART2129ACR REF - TOP MOUNT
Amana ART2129ASR REF - TOP MOUNT
Amana ART2129AWR REF - TOP MOUNT
Amana ART2527AB REF - TOP MOUNT
Amana ART2527AC REF - TOP MOUNT
Amana ART2527AW REF - TOP MOUNT
Amana ART5400L RANGE- STD MWAVE ELE
Amana ART5400W RANGE- STD MWAVE ELE
Amana ART6000L RANGE- S/C S/I DDRAFT GAS
Amana ART6000W RANGE- S/C S/I DDRAFT GAS
Amana ART6001L RANGE- S/C S/I DDRAFT GAS
Amana ART6001W RANGE- S/C S/I DDRAFT GAS
Amana ART6002L RANGE- S/C S/I DDRAFT GAS
Amana ART6002L Range - S/c S/i Ddraft Gas
Amana ART6002W RANGE- S/C S/I DDRAFT GAS
Amana ART6002W Range - S/c S/i Ddraft Gas
Amana ART6021C RANGE- S/C S/I DDRAFT GAS
Amana ART6021L RANGE- S/C S/I DDRAFT GAS
Amana ART6021W RANGE- S/C S/I DDRAFT GAS
Amana ART6100E RANGE- S/C S/I DDRAFT GAS
  #2 (permalink)
Old 12-17-2011, 12:50 AM
Jeff / APP Team's Avatar
Senior Expert
Jeff / APP Team is on a distinguished road
Default
Hello Minidrivr. Yes, the secondary valve supplies the ice maker. Based on the information you provided, it sounds like the valve is bad and will need to be replaced. Hope this helps.
Part number: AP4009555
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Jeff K. / APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 12-17-2011, 09:01 AM
Junior Member
Default
Thanks Jeff! I'll order the valve today.
  #4 (permalink)
Old 12-22-2011, 12:11 AM
Junior Member
Default
New valve installed and working fine. So far so good.
The old valve used a threaded fitting on the intake water line. The new one used a push on fitting like the output lines. If one of these fittings is seeping water, how do you seal them? Can the line be removed and reinserted? I made sure they were fully seated but the intake line is leaking slightly. Which unfortunately when it drips it's right on top of the electrical connection for the primary water valve.
  #5 (permalink)
Old 12-22-2011, 10:24 AM
Senior Expert
Default
Hello. Yes, you will press down on the plastic fitting and pull the line out of the valve. Take a knife and make a clean cut past where the nut was on the line. Then push the line back into the valve. This should repair the leak. Hope this helps.
__________________
Jeff K. / APP TEAM
  #6 (permalink)
Old 12-22-2011, 04:43 PM
Junior Member
Default
I made new clean cuts but I'll try a new cut again when I get the hose out of the fitting.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
amana bottom freezer not freezing graygoose54@yahoo.com Refrigerator & Freezer Repair 0 08-02-2011 08:09 AM
Amana Refridgerator - freezer not freezing VTRI Refrigerator & Freezer Repair 0 07-25-2010 07:33 PM
Amana freezer not freezing hazimalac Refrigerator & Freezer Repair 3 07-14-2009 11:21 PM
Ice maker funnel repair jhackman Refrigerator & Freezer Repair 1 05-18-2009 04:33 PM
Amana Refer Freezing Food Dswinty Refrigerator & Freezer Repair 2 01-12-2009 11:28 PM
