| » Whirlpool intermittent water leak |
Model Number: ED5VHEXVQ00 Brand: Whirlpool Age: Less than 1 year
Just bought this thing last November. I'm wondering if I got a lemon as I had to call for service for the ice maker after 2 months (so far, that's working OK now).
Current problem is a random water leak. Happens very fast, too. I'll walk by the fridge and the floor is dry. Maybe an hour later, there will be a puddle of water in the front of the fridge (maybe about a half to one cup of water in volume). This has happened 3x now in one month. Every time it happens, I take the bottom cover off to figure out where the leak is coming from. It looks like it's coming from the defrost drip tray, maybe to the right of that tray. But every time, it's definitely coming from under the fridge. Every time, I'll lay a towel down in front to sop up the water and take it away after 10 minutes. No leaking after that until the next episode. I've had two different service companies (both contracted out by Whirlpool) out and neither can find the problem. For the first time it leaked a month ago, the first company sent someone who barely looked under the fridge. Since there was no leak, he decided not to look any further. The second time it leaked was Tuesday of this week. The second company that came out was much better, but he still couldn't find the problem. He looked under, took the back cover off and looked back there, checking for valve leaks, etc. He did give me a few ideas and places to look. He thought it might be coming from the ice dispenser (we keep it on crushed ice and some of the ice accumulates in the area above the dispenser in the door). I did tell him that I've never noticed water running down the front of the door under the dispenser, so I didn't think it was that problem. I told him I suspected it might be an intermittent problem w/the defrost cycle and he thought there was a chance it might be a problem there, too. The day he came out, the refrigerator leaked again in the evening. Too bad it couldn't have happened while he was there. Basically, it's a fairly big leak, but it kind of gushes then stops for a while. It's definitely not from ice that might have dropped on the floor below the dispenser. Too much water for that. Anyone ever see a similar problem w/a side by side fridge (w/water and ice dispenser--even though I don't think this is causing the problem)? Ads By Google Related Models |
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
We have the same ED2VHEXVQ00 Whirlpool Fridge and we have the same problem with ours too. Check at the bottom of the freezer underneath the slide-out tray and you'll see a sheet of ice and water going down the side to the floor. We don't know why ice builds up and leaks, but it lasts longer to clean that out. If you can find a service person to solve this problem please let me know.
-Thank you hope this helps |
Hi.
Reed this, please. Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flushing it out with hot water and Clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer. Read more: Whirlpool intermittent water leak http://forum.appliancepartspros.com Thank you. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Intermittent water leak - Kitchen Aid side by side | greg88 | Refrigerator & Freezer Repair | 1 | 10-08-2009 01:13 PM |
| GE S by S Intermittent Water Leak At Top | SERVEL | Refrigerator & Freezer Repair | 0 | 08-22-2009 05:05 AM |
| whirlpool Calypso water leak | Joseph Rotenberg | Washer Repair | 1 | 08-07-2009 07:38 AM |
| Whirlpool Refrigerator Water Leak | wrightmd11 | Refrigerator & Freezer Repair | 3 | 03-10-2009 05:28 PM |
| Whirlpool Water Leak | Mike Knox | Dishwasher Repair | 1 | 03-01-2009 01:58 AM |
