AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Freezer making ice but will not freeze ice cream everything else seems ok?
I have a Sub Zero the refrigerator is cooling just fine and so is the freezer except I have ice cream that is very soft. Nothing else is defrosting and it is making ice. I can hear the motor running but cannot tell if a fan is running. The motor is on the top and the freezer on the bottom. Thanks,
I love ice cream.......
All Sub-Zeros are very sensitive to condenser coil condition. It has to be cleaned at least once a year. That's probably the cause of the problem.
Basically it does not matter which model is your refrigerator. The condenser needs cleaning at least once a year.
Originally Posted by: Gene All Sub-Zeros are very sensitive to condenser coil condition. It has to be cleaned at least once a year. That's probably the cause of the problem.
Gene. Hi Gene, Thanks for the reply but how do I clean the coil? With a vacum very carefully I assume? Need more instruction. Thank you,
I would recommend to call a refrigeration pro to do it for you fist time. You'll learn how to do it right way and later will do it yourself.
Originally Posted by: Gene I would recommend to call a refrigeration pro to do it for you fist time. You'll learn how to do it right way and later will do it yourself.
Gene. Gene, I can't afford a repair pro right now I just lost my job. Please give me a hint on how to do it. I will be very careful. Thanks
