blueyes
#1 Posted : Friday, June 26, 2009 7:57:52 AM(UTC)
blueyes
do I replace the control board,have ohmed out heating element,ok.how do i check the thermostat control?
#2 Posted : Friday, June 26, 2009 8:10:31 AM(UTC)
Replacement parts for FRG FRS26R4CB0 | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/p...f/Anderson/240389610.pdf
Try to force a defrost, see the tech sheet.
If the heater heats up then the adaptive defrost board is probably shot.
If it does not heat up it still could be any one of the 3 defrost components.
To check the defost thermostat by itself, it must be frozen as it opens just above freezing.
If the freezer is above freezing hold the defrost thermostat's face onto an ice cube. It should be 0 ohms when frozen.
Also sometimes you can see that it is shot as it will be bulged out.
Fridge will not defrost properly (Refrigerator & Freezer Repair)
by smackum 12/14/2014 8:43:04 AM(UTC)
Freezer will not defrost (Refrigerator & Freezer Repair)
by todhurd 9/26/2013 11:54:42 AM(UTC)
Freezer will not Defrost (Refrigerator & Freezer Repair)
by friendlytx2 4/14/2012 10:36:49 AM(UTC)
evap coil is freezing up will not defrost (Refrigerator & Freezer Repair)
by Chrisca 7/16/2011 8:59:43 PM(UTC)
'02 Whirlpool will not defrost (Refrigerator & Freezer Repair)
by py7juh 4/6/2011 12:19:15 PM(UTC)
GE fridge will not defrost correctly (Refrigerator & Freezer Repair)
by Webberette 9/23/2010 1:01:56 PM(UTC)
freezer will not defrost (Refrigerator & Freezer Repair)
by mph151 7/23/2010 8:41:43 AM(UTC)
by mrnonutz 6/16/2010 8:17:10 AM(UTC)
by MarcusPizzorno 10/26/2009 11:35:52 AM(UTC)
by barneyrubble 6/8/2009 6:16:00 PM(UTC)
Frigidaire: Freezer will not Defrost (Refrigerator & Freezer Repair)
by dbolan 4/28/2009 5:06:19 AM(UTC)
