this is going to take a minute to write.Ive bought a circuit boar for my refridgerator/freezer and im not sure it will work the differences are mine has only 1 capacitor yours has 2 and mines got only 4 relays yours has 6 mine only has 4 plugs on top yours has 6 the little green wire on the side mines got a plug and no ground strap your has the green wire with a ground strap mine is a side by side and by the instructions it shows cutting a wire but ui think its for a bottom freezer will this work and how thank you
Joel,
What is the part number of the control board in question?
What exactly is wrong with your refrigerator?
Gene. the part number is wr55x10942 the freezer/refridgerator is a ge its possible this is the one but just doesnt look right ty for the responce
GE had a lot of problems with this control board. It has been redesigned a few times. That's why this control board looks so different. This part number is the correct part number for your refrigerator.
Originally Posted by: Gene GE had a lot of problems with this control board. It has been redesigned a few times. That's why this control board looks so different. This part number is the correct part number for your refrigerator.
Gene. the little green wire which is the ground wire is different the wire i have is a single plug wire is that a ground wire also cause i see the new one has a eyelet other than that theres 2 extra plug adapters and what do i do with that plug for the ground just let it hang
