My ice and water dispenser is not working. Wife had a repairman come out and he said the board is bad and it's $294 to fix it. I'm wondering if I can replace the board myself. But, there's two boards, connected with a harness. How do I know which one to replace?
Originally Posted by: Gene So can I simply unscrew the part and replace it? Do I have to ground myself to the refrigerator? Does the harness simply unplug from the board? Or how does that work? Thanks for your help...
Quote:So can I simply unscrew the part and replace it? Yes, you can. Quote:Do I have to ground myself to the refrigerator? No, you don't. Quote:Does the harness simply unplug from the board? Yes, it does. Gene.
Originally Posted by: Gene Yes, you can.
No, you don't.
Yes, it does.
Gene. Awesome, thanks for the info. I'll order the part!
