Hi all Have had a problem with fridge not running, was told it may be the overload fixed that, Fridge ran fine for a day or so then stopped, noticed that the back wall of freezer was frozen, doesn't seem to be entering into a defrost cycle, which is causing it to not run. Upon it thawing out by leaving it open it sarts to run again. What is causing this?
A defrost problem would be cause by one of three things.
1. Bad defrost timer 2. Bad defrost thermostat 3. Bad defrost heater
