| » Freezer cold, but fridge warm |
Model Number: msd2756geb Brand: Maytag Age: 1 - 5 years
Found Ice Locking The Vent Down In The Lower Left Fridge Side, Below The Crisper Boxes. Cleaned It Out, Lasted 1-2 Weeks And Refroze. When Turning Freezer Off, I Had Much Water From Thawing. Any Ideas? Thank You, Doug
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer
If you have a defrost problem, there will be ice buildup on the evaporator coils behind the back cover in the freezer. It will build up and block the air flow. When the defrost system works it melts the frost and the water drains down to the drain pan.
| Display Modes | |
| Freezer cold, fridge warm - please help !! | aviator2010 | Refrigerator & Freezer Repair | 5 | 09-27-2009 12:40 PM |
| Fridge warm, freezer cold | angiebaaaby | Refrigerator & Freezer Repair | 8 | 11-19-2008 08:46 PM |
| Freezer too cold, Fridge too warm | Neffa | Refrigerator & Freezer Repair | 3 | 09-23-2008 11:12 AM |
| Freezer cold/Fridge Warm | ssines | Refrigerator & Freezer Repair | 1 | 01-08-2008 09:23 PM |
| Fridge & Freezer Cycle Cold To Warm Back To Cold | terkel | Refrigerator & Freezer Repair | 1 | 09-25-2007 02:58 AM |
