My freezer alarm goes off about twice in 24 hours. I unplug the freezer and plug it back in to stop the alarm. Freezer is still freezing but not as solid as it should be, some things are not froze real solid. This is an upright frostless that sucks the air out when the door is closed, but it does not suck the air out any longer, since the alarm has been going off. I have check the seal all around the door and it is clean and seems to be sealing good.
