Appliance Repair Forum
-   Refrigerator & Freezer Repair (http://forum.appliancepartspros.com/refrigerator-freezer-repair/)
-   -   Amana Evaporater Fan Noise (http://forum.appliancepartspros.com/refrigerator-freezer-repair/3780-amana-evaporater-fan-noise.html)
gemret 12-27-2007 04:28 PM
Could someone tell me how to go about removing the evaporater fan motor? There must be a repair manual somewhere that shows the repairmen how to do this. If anyone has a manual or could explain it I would appreciate it.:confused:
misterfixall 12-27-2007 07:22 PM
the original motor is nla .you will have to in stall a universal fan motor . i dont know your mechanical abilitys when modifying replacement fan motor .you may have to reverse windings , shorten shaft, brackets. etc.fan is held on by 2 screws +2 wires +may be ground wire. you may have to remove fan cover good luck or get tech.
richappy 12-27-2007 07:51 PM
I use a SM999 motor,fairly cheap and reliable. You might have to reverse the motor rotor if it turns the wrong way. Most web part sites show parts assembly.
