Discuss
Will not run in cold weather
 in
Refrigerator & Freezer Repair
When purchased new 2 yrs. ago, told sales person it was for the garage to be used as 2'nd
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Will not run in cold weather
  #1 (permalink)
Old 12-27-2007, 03:07 PM
garry daywitt garry daywitt is offline
Junior Member
garry daywitt is on a distinguished road
Default Will not run in cold weather
Brand: Frigidaire   Age: 1 - 5 years
When purchased new 2 yrs. ago, told sales person it was for the garage to be used as 2'nd frige for pop, beer, etc.
Live in Utah, today is 20 degrees, last winter lost all food in freezer to thawing. Found manual, only to see it states a minimum temperature for operation ( room temp.) of 55 degrees. Freezer is again getting warm.
Can this default temp be set lower or disconnected?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-27-2007, 04:39 PM
TechnicianBrian's Avatar
TechnicianBrian TechnicianBrian is offline
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
Many Frigidaire refers have what's called a cold weather kit that consists of a heater that is placed near the operating thermostat to trick it into working when the temperature drops below 55 degrees. The model number would be needed to locate the correct item.
__________________
TechnicianBrian
TechnicianBrian.com
Appliance Repair Blog
  #3 (permalink)
Old 12-27-2007, 08:53 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
NOT a good idea. Must heat compressor also or it will be hard starting as compressor oil will congeal!!
__________________
  #4 (permalink)
Old 12-28-2007, 01:15 PM
Junior Member
Default
Brian,
Thanks for the quick reply, model is FRT18KB2DWA. Are you referring to a thermostat on the compressor for room temp. ?
  #5 (permalink)
Old 12-28-2007, 03:31 PM
Senior Expert
APP Volunteer
Default
This is a kit that keeps the control thermostat at a warmer state so it will continue to cycle even when the ambient temperature would normally keep it from cycling. It's made by Frigidaire for their units and will prevent food loss in the freezer section during short cold snaps. If the unit is spending days in the cold, or if it is exposed to very cold temps, it needs to be put in a warmer location.
__________________
TechnicianBrian
TechnicianBrian.com
  #6 (permalink)
Old 01-28-2008, 01:59 PM
Forest Bridger Forest Bridger is offline
Junior Member
Forest Bridger is on a distinguished road
Default
I ordered the "garage kit" for cold weather but can't find out where/how it's to be installed. What are your thoughts?
  #7 (permalink)
Old 01-28-2008, 03:48 PM
kooler kooler is offline
Senior Expert
APP Volunteer
kooler is on a distinguished road
Default another option
I have a home brewing buddy who had the same problem and I installed a commercial temp control that used a wide range scale in his garage fridge... Still working great today... Some can be rather spendy but I imagine beLowe's or Home Repot would have a moderately priced one...
__________________
  #8 (permalink)
Old 01-28-2008, 08:47 PM
Senior Expert
APP Volunteer
Default
The garage kit comes with an installation sheet complete with photos to aid in installation. Once you see it, you will see there is only one way for it to be installed. No problem 10 minutes tops.
__________________
TechnicianBrian
TechnicianBrian.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
no cold water alone coming in .do get hot or warm. so cold must be comin through valv misterfixall Washer Repair 1 11-16-2007 01:51 PM
sometimes not as cold as should be gpete Refrigerator & Freezer Repair 2 10-17-2007 03:59 PM
Fridge & Freezer Cycle Cold To Warm Back To Cold terkel Refrigerator & Freezer Repair 1 09-25-2007 03:58 AM
Freezer has frost and cold/frig is not very cold DinATL Refrigerator & Freezer Repair 1 09-14-2007 08:38 PM
Cold/Cold will not work, all others do work!? MiniPants Washer Repair 10 08-30-2007 08:02 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
