Discuss
water dispenser not working
 in
Refrigerator & Freezer Repair
water is working with the ice maker and filter but will not pressure up to the spigot in the door.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » water dispenser not working
  #1 (permalink)
Old 12-27-2007, 07:51 AM
ol bob ol bob is offline
Junior Member
ol bob is on a distinguished road
Default water dispenser not working
Model Number: GSH25KGRE BB   Brand: GE   Age: 1 - 5 years
water is working with the ice maker and filter but will not pressure up to the spigot in the door. i have pressure to the bottom of the door but it will not go on up through the line. it has done this several times in the last year. i can usually jiggle the line and it resumes working, but not this time. any suggestions?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-27-2007, 12:00 PM
TechnicianBrian's Avatar
TechnicianBrian TechnicianBrian is offline
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
If you can disconnect the line at the bottom of the door, actuate the dispenser lever and have water come out, then you water line inside the door is probably frozen. You can try heating the inside of the door with a hairdryer to thaw it and see if it starts working again. Sometimes the doors are made with the water line to close to the inner liner allowing cold air to freeze the remaining water after use. No good fix for it other than replacing the door.
__________________
TechnicianBrian
TechnicianBrian.com
Appliance Repair Blog
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water Dispenser quit working rhondalrowley Refrigerator & Freezer Repair 5 08-07-2008 08:08 AM
Ice Maker NOT working, water dispenser fine KnK6971 Refrigerator & Freezer Repair 0 10-26-2007 05:30 PM
ice dispenser working...water dispenser not rishuk Refrigerator & Freezer Repair 0 09-25-2007 04:03 PM
ice dispenser not working braindr Refrigerator & Freezer Repair 0 09-12-2007 08:33 PM
Water Dispenser/Ice Maker not working Michael_Timberblind Refrigerator & Freezer Repair 3 09-02-2007 07:16 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
