water dispenser not working
water is working with the ice maker and filter but will not pressure up to the spigot in the door. i have pressure to the bottom of the door but it will not go on up through the line. it has done this several times in the last year. i can usually jiggle the line and it resumes working, but not this time. any suggestions?
If you can disconnect the line at the bottom of the door, actuate the dispenser lever and have water come out, then you water line inside the door is probably frozen. You can try heating the inside of the door with a hairdryer to thaw it and see if it starts working again. Sometimes the doors are made with the water line to close to the inner liner allowing cold air to freeze the remaining water after use. No good fix for it other than replacing the door.
| All times are GMT -7. The time now is 01:15 PM. |
