| » PAKMANs Water drip in the Frig |
Model Number: 106.71184101 Brand: Kenmore Age: 1 - 5 years
I have a frezer on top of my frig. The frezer seems to be fine. I have water dripping from a housing in the upper back of my frig. It is not constent but it is frequently. I recently moved my frig to lay down new tile. I do not use the water tubing for the icemaker. No apparent damage was done during the moving of the frig. The dripping started about a week after I moved the frig back. Any help would be greatly appreciated, thank you. PAKMAN
sounds like the drain trough is blocked .you will have to acess the feezer coils behind freezer back cover .you will probably see lot of ice ,like a skating rink .that ice willhave to be carefully removed the use a hair dryer to defrost drain hole , this will take quite awhile . if you can turn off fridge over night and let it defrost on its own.then i use an air compressor ,locate drain hole indrain trough +and blow out drain under pressure to clear any blockage . then pour water in hole till i hear it running into drain pan at back of fridge behind panel.if you have a shop vac ,use it to remove water from pan
__________________
Quote:
This will take forever. Just remove the back freezer panel and locate the drain hole under the evaporator coils, will be frozen over.
Boil some water and pump it in the drain hole with a turkey baster. Suck out the now cold water, then repeat pumping in hot water till the drain runs free. Measure the back wall freezer temperature when done, if super cold, like zero or below, adjust your freezer control till it's higher. Also, you can wrap a thick copper or aluminum wire around the defrost heater and then down the drain. This should solve your problem.
__________________
why did this blockage occur in first place ,water itself woud not cause blockage , important to blow out drain ,in my area calcification due to hard water can build up in drain.
__________________
| Display Modes | |
| water dispenser drip | mrl | Refrigerator & Freezer Repair | 0 | 01-26-2010 10:08 AM |
| water drip pan | keith82901 | Refrigerator & Freezer Repair | 1 | 07-17-2009 06:58 PM |
| water drip pan | keith82901 | Refrigerator & Freezer Repair | 0 | 07-17-2009 01:25 PM |
| water drip pan | keith82901 | Refrigerator & Freezer Repair | 0 | 07-17-2009 01:20 PM |
| Should there ever be water in drip pan of refrigerator? | pcumming | Refrigerator & Freezer Repair | 2 | 06-13-2009 05:59 AM |
