I need to know the cubic feet of the refrigerator model listed above. I checked inside the frig. Nothing stated on the tag. Thanks - Fourkoals
You can tell by the 20 in the model number. Good chance it's 20 point (20.?) some Cu. Ft and the manufacture may round it off and call it a 21 Cu. Ft. refrigerator.
thanks for such a quick answer!!
To get the true capacity, open the compartment door and measure the depth, width, ane height inside the compartment. Do this for both the fresh food compartment, and for the freezer. Multiply the dimensions together (D x W x H) in feet. The result will be cubic feet for that compartment. The sum of them both will be the total capacity for the unit.
