bpetska
#1 Posted : Tuesday, June 16, 2009 8:44:09 AM(UTC)
bpetska
the compressor runs but the refridgerator does not cool
#2 Posted : Tuesday, June 16, 2009 11:11:44 AM(UTC)
What is exact temperature in the freezer and refrigerator?
Does the fan in the freezer run?
Check if there is a frost on the rear panel in the freezer?
bpetska
#3 Posted : Tuesday, June 16, 2009 2:46:10 PM(UTC)
bpetska
Gene,
The temperature is the same in the freezer as in the refridgerator. Room temperature. The fan runs in the freezer. There is no frost in the back of the freezer.
#4 Posted : Tuesday, June 16, 2009 5:15:10 PM(UTC)
If the compressor is running, but there is room temperature in both compartments then the system is low on Freon or the compressor is not pumping Freon. It has to be checked by a certified tech.
