Kewoldt
#1 Posted : Saturday, December 3, 2011 7:13:17 PM(UTC)
Kewoldt
Ice maker stopped working. Replaced filter, water dispenser is working fine, but no water appears to be going into ice trays. Red LED light flashing, turned off the unit, then back on, light still flashing. No obstruction on flopper door...any help for me? Thanks
ApplianceJunk
#2 Posted : Saturday, December 3, 2011 7:26:32 PM(UTC)
ApplianceJunk
I would first check to see if the water line between the water inlet valve to the ice maker is not frozen shut. I do this by blowing air through it.
Then I would check the water inlet valve.
Can be checking with a ohm meter or home made test cord to apply power to it.
If the water line is not frozen and the water inlet valve test ok I would suspect the ice maker is at fault.
I most often find a frozen water line or faulty ice maker on this type of refrigerator.
Kitchenaid icemaker not working (Refrigerator & Freezer Repair)
by gmpfeffer 2/24/2013 1:42:19 PM(UTC)
Kitchenaid Icemaker not working (Refrigerator & Freezer Repair)
by Stekelenburg 12/12/2012 9:55:44 AM(UTC)
by Dan54 2/28/2011 11:39:01 PM(UTC)
KitchenAid icemaker not working (Refrigerator & Freezer Repair)
by Anilkumar15 12/31/2010 5:44:41 PM(UTC)
by jjjacek 6/5/2010 4:45:22 AM(UTC)
Kitchenaid Icemaker Not Working (Refrigerator & Freezer Repair)
by Doug_dallas 6/8/2009 2:00:59 PM(UTC)
by jayconnor 12/30/2007 7:15:37 AM(UTC)
