My freezer is not making ice cubes. The infared sensor on the inside of the door is blinking red whenever i open the door and hold the light switch closed. The water on the door is working. I took the supply tube off from the back of the unit and blew into it causing air to come out through the freezer where the water would fill the tray. Any ideas Thank you
