Discuss
Fridge is warm
 in
Refrigerator & Freezer Repair
Hey everyone, Bought a house with a 5 year old side by side fridge and found a work order replacing
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Fridge is warm
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-23-2007, 03:56 PM
hotbrick hotbrick is offline
Junior Member
hotbrick is on a distinguished road
Default Fridge is warm
Model Number: frs262rgb?   Brand: Frigidaire   Age: 1 - 5 years
Hey everyone,
Bought a house with a 5 year old side by side fridge and found a work order replacing a defrost timer about 2 and a half years ago. Well today the fridge quit working but freezer is ok. After reading in this forum I took the back out of freezer and found the coils froze up. I defrosted the freezer and that seemed to help. But I have a couple of questions
1 Is just defrosting a quick sollution?
2 Is it normal for a timer to go out in a couple of years?
3 Do I need to replace timer AGAIN or something else?
Thanx....hotbrick
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-23-2007, 07:40 PM
abbie abbie is offline
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
The first answer to the question is that defrosting coils will not solve the problem .It sounds like you have a defrosting problem which can be one of three things, that,s if it,s not and electronic fridge.First it could be the timer or defrost thermostat[bi-metal] or the heater If you know where to find the timer,you can manually set in into defrost by turning the center button of the timer slowly clockwise until the fridge shuts off this is when it will be into defrost. Put you ear into the freezer section and listen for cracking and hissing noises after a few minutes. If you here this ,then your timer is bad.BUT if you here nothing then it could be you bi-matel or your heater, To check these parts you could jump the bi-metal when the freezer is cold inside,or check with a meter both bi-metal and heater to see if there is continity. BUT IF YOU JUMP THE BI-METAL AND FIND THE HEATER TO WORK DO NOT LEAVE IT JUMPED. REPLACE THE BI-METAL WITH A NEW ONE , BECAUSE THE BI-METAL IS A SAFTY DEVICE... GOOD LUCK
__________________
  #3 (permalink)
Old 12-23-2007, 07:48 PM
Junior Member
Default
Thanx for the quick reply abbie. Everywhere I read on this site says that it might be my defrost timer. Is there a good site (maybe this one but cant find it) where I can look at a cross section of my fridge to see where these parts are located??..Thanx
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fridge & Freezer both warm wdvfd1335 Refrigerator & Freezer Repair 1 03-29-2008 04:47 PM
freezer works, fridge is warm debssanity Refrigerator & Freezer Repair 8 01-02-2008 07:26 PM
Fridge and Freezer both Warm xsivspeed454 Refrigerator & Freezer Repair 4 12-06-2007 05:39 AM
warm fridge carson Refrigerator & Freezer Repair 5 12-05-2007 12:31 PM
Freezer warm - Fridge warm Carolyn Refrigerator & Freezer Repair 1 10-29-2007 04:33 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
