changed compressor added 4.8 ounces of freon.running now for 24 hrs freezer and frig. are only cooling to 45 degrees, can somebody help me please, thank you
Before charging, you must replace the dryer and vacumm the system. When charging, you must purge any air out of the fill lines. If done properly,there is a possability you have a evaporator leak which can be found using flourescent die.
