acudocdns
#1 Posted : Wednesday, June 10, 2009 7:28:46 PM(UTC)
acudocdns
This frig started make a grinding noise tonight ... sounds like a fan. It is not the condenser fan... I took a look and all is well. the noise is up top appeal loader when the doors are open... I need some ideas here as I have no idea what it could be???:confused:
David
woodchuckie
#2 Posted : Thursday, June 11, 2009 4:52:14 AM(UTC)
woodchuckie
You also have a fan in the freezer called the evaporator fan. It can be loud if it's wore out or it can be hitting ice build up. In which case you may have a defrost problem. Here's a diagram of your fan. It appears to be in the top behind a cover on the back.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=25351622101&productCategoryId=0165000&brandId=0582&modelName=SIDE-BY-SIDE-REFRIGERATOR&diagramPageId=00005&componentDescription=CONTROLS&documentId=P0106200&backToLink=Return%20to%20Sub%20Components%20list
acudocdns
#3 Posted : Thursday, June 11, 2009 8:35:33 PM(UTC)
acudocdns
So I turned off the breaker to the frig.... and when I turned it back on the noise was gone ... and is still gone. Maybe there was a piece if ice in the fan?
How would I know if I have a heater problem??:rolleyes:
acudocdns
#4 Posted : Friday, June 12, 2009 5:55:20 AM(UTC)
acudocdns
Ok .. the evaperator fan noise is back... so the question is do I have a heater problem aof a fan problem ... or both.
Of course I do not wanr to order extra part ... but I have to get this done:eek:
woodchuckie
#5 Posted : Friday, June 12, 2009 6:54:59 AM(UTC)
woodchuckie
It seem to be maybe a fan loose on the shaft or maybe a loose motor mount. When you gain access to it you might be able to see why it makes a noise at times. I don't think the heater would cause it.
acudocdns
#6 Posted : Friday, June 12, 2009 6:57:51 AM(UTC)
acudocdns
Thanks ... I will take it apart asap
acudocdns
#7 Posted : Monday, July 13, 2009 8:05:23 PM(UTC)
acudocdns
Well, I finally took the frig apart... and it was just ice builld-up over 10+ years.
Removed ice and lll is well!
