Discuss
Kenmore Side-by-Side - Drain pan overflow after fixing ice door chute. Coincidence?
 in
Refrigerator & Freezer Repair
Hello All, I need your expertise to solve a leak that I'm experiencing the day after fixing/replacing the ice chute
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kenmore Side-by-Side - Drain pan overflow after fixing ice door chute. Coincidence?
  #1 (permalink)
Old 06-10-2009, 11:37 AM
Junior Member
jeaton is on a distinguished road
Question Kenmore Side-by-Side - Drain pan overflow after fixing ice door chute. Coincidence?
Model Number: 10652544101   Brand: Kenmore   Age: 5 - 10 years
Hello All,
I need your expertise to solve a leak that I'm experiencing the day after fixing/replacing the ice chute door.
I have a Kenmore/Whirlpool side-by-side and the drain pan (evaporator tray) overflows and leaves a large puddle on the floor. I vacuumed all the water out of the tray, checked the door seal, freezer drain and water source inlet connections and all look good. When I had the freezer pulled away from the wall, looking in at the bottom of the unit, I could observe that at times water would trickle out of the drain tube into the evap tray and a pretty good pace, but then stop for a while and then start again. I would guess perhaps an ounce each time.
The day prior, I had replaced the ice door chute by taking off the front panel, disconnecting the main connector and the door chute connector (note the original ice door chute had a small heater ribbon circuit to evaporate condensation). I installed the new door chute (2180353) which doesn't have the heater circuit, reassembled the front panel and all controls work okay. And I no longer have the frosting/crystalization around the upper portion of the chute.
Is there a connection between the two? Could removing the door chute heater connector from the circuit be a factor, or is just a coincidence? Is it possible that a tube/pipe on the interior cracked while moving the unit out of and back into position? I haven't removed the rear panel yet, but expect that is the next logical step. Since turning off the water source, the drain pan doesn't fill and overflow, which leads me to think there's a cracked tube on the inside.
Let me know if this makes sense or if the ice chute door repair/replacement is a factor.
Thanks for your input!
Jon
Ads By Google
Related Models
Kenmore 10653082300 REFRIGERATOR
Kenmore 10653084300 REFRIGERATOR
Kenmore 10653092300 REFRIGERATOR
Kenmore 10653094300 REFRIGERATOR
Kenmore 10653202200 REFRIGERATOR
Kenmore 10653202201 REFRIGERATOR
Kenmore 10653202202 REFRIGERATOR
Kenmore 10653203201 REFRIGERATOR
Kenmore 10653203202 REFRIGERATOR
Kenmore 10653204201 REFRIGERATOR
Kenmore 10653204202 REFRIGERATOR
Kenmore 10653206201 REFRIGERATOR
Kenmore 10653206202 REFRIGERATOR
Kenmore 10653209201 REFRIGERATOR
Kenmore 10653209202 REFRIGERATOR
Kenmore 10653232300 REFRIGERATOR
Kenmore 10653234300 REFRIGERATOR
Kenmore 10653242300 REFRIGERATOR
Kenmore 10653244300 REFRIGERATOR
Kenmore 10653252200 REFRIGERATOR
Kenmore 10653252201 REFRIGERATOR
Kenmore 10653252202 REFRIGERATOR
Kenmore 10653254200 REFRIGERATOR
Kenmore 10653254201 REFRIGERATOR
Kenmore 10653254202 REFRIGERATOR
Kenmore 10653259200 REFRIGERATOR
Kenmore 10653259201 REFRIGERATOR
Kenmore 10653259202 REFRIGERATOR
Kenmore 10653262200 REFRIGERATOR
Kenmore 10653262201 REFRIGERATOR
Kenmore 10653264200 REFRIGERATOR
Kenmore 10653264201 REFRIGERATOR
Kenmore 10653269200 REFRIGERATOR
Kenmore 10653269201 REFRIGERATOR
Kenmore 10653270300 REFRIGERATOR
Kenmore 10653272300 SXS REFRIGERATOR
Kenmore 10653276300 SXS REFRIGERATOR
Kenmore 10653292200 REFRIGERATOR
Kenmore 10653292201 REFRIGERATOR
Kenmore 10653292202 REFRIGERATOR
Kenmore 10653293200 REFRIGERATOR
Kenmore 10653293201 REFRIGERATOR
Kenmore 10653293202 REFRIGERATOR
Kenmore 10653294200 REFRIGERATOR
Kenmore 10654202300 REFRIGERATOR
Kenmore 10654203300 REFRIGERATOR
Kenmore 10654204300 REFRIGERATOR
Kenmore 10654209300 REFRIGERATOR
Kenmore 10654212300 REFRIGERATOR
Kenmore 10654213300 REFRIGERATOR
Kenmore 10654214300 REFRIGERATOR
Kenmore 10654219300 REFRIGERATOR
Kenmore 10654263300 REFRIGERATOR
Kenmore 10654273300 REFRIGERATOR
Kenmore 10654282200 REFRIGERATOR
Kenmore 10654282201 REFRIGERATOR
Kenmore 10654284200 REFRIGERATOR
Kenmore 10654284201 REFRIGERATOR
Kenmore 10654382300 REFRIGERATOR
Kenmore 10654383300 REFRIGERATOR
Kenmore 10654384300 REFRIGERATOR
Kenmore 10654389300 REFRIGERATOR
Kenmore 10654392300 REFRIGERATOR
Kenmore 10654393300 REFRIGERATOR
Kenmore 10654394300 REFRIGERATOR
Kenmore 10654399300 REFRIGERATOR
Kenmore 10654563300 REFRIGERATOR
Kenmore 10654573300 REFRIGERATOR
Kenmore 10654602300 REFRIGERATOR
Kenmore 10654603300 REFRIGERATOR
Kenmore 10654604300 REFRIGERATOR
Kenmore 10654609300 REFRIGERATOR
Kenmore 10654612300 REFRIGERATOR
Kenmore 10654613300 REFRIGERATOR
Kenmore 10654614300 REFRIGERATOR
Kenmore 10654619300 REFRIGERATOR
Kenmore 10654682300 REFRIGERATOR
Kenmore 10654683300 REFRIGERATOR
Kenmore 10654684300 REFRIGERATOR
Kenmore 10654689300 REFRIGERATOR
Kenmore 10654692300 REFRIGERATOR
Kenmore 10654693300 REFRIGERATOR
Kenmore 10654694300 REFRIGERATOR
Kenmore 10654699300 REFRIGERATOR
Kenmore 10656071790 REFRIGERATOR
Kenmore 10656071791 REFRIGERATOR
Kenmore 10656072790 REFRIGERATOR
Kenmore 10656072791 REFRIGERATOR
Kenmore 10656075790 REFRIGERATOR
Kenmore 10656077790 REFRIGERATOR
Kenmore 10656077791 REFRIGERATOR
Kenmore 1065645180 COLDSPOT DEHUMIDIFIER
Kenmore 1065649190 COLDSPOT DEHUMIDIFIER
Kenmore 10657021790 REFRIGERATOR
Kenmore 10657021791 REFRIGERATOR
Kenmore 10657022790 REFRIGERATOR
Kenmore 10657022791 REFRIGERATOR
Kenmore 10657028790 REFRIGERATOR
Kenmore 10657028791 REFRIGERATOR
Kenmore 10657051790 REFRIGERATOR
Kenmore 10657051791 REFRIGERATOR
Kenmore 10657051792 SIDE BY SIDE REFRIGERATOR
Kenmore 10657058790 REFRIGERATOR
Kenmore 10657058791 REFRIGERATOR
Kenmore 10657058792 SIDE BY SIDE REFRIGERATOR
Kenmore 10657071790 REFRIGERATOR
Kenmore 10657072790 REFRIGERATOR
Kenmore 10657072791 REFRIGERATOR
Kenmore 10657075790 REFRIGERATOR
Kenmore 10657075791 REFRIGERATOR
Kenmore 10657077790 REFRIGERATOR
Kenmore 10657232790 REFRIGERATOR
Kenmore 10657237790 REFRIGERATOR
Kenmore 10657262790 REFRIGERATOR
Kenmore 10657262791 REFRIGERATOR
Kenmore 10657262792 SIDE BY SIDE REFRIGERATOR
Kenmore 10657267790 REFRIGERATOR
Kenmore 10657267791 REFRIGERATOR
Kenmore 10657267792 SIDE BY SIDE REFRIGERATOR
Kenmore 10657282790 REFRIGERATOR
  #2 (permalink)
Old 06-10-2009, 01:35 PM
Hardcore DIY'er
APP Volunteer
woodchuckie is on a distinguished road
Default
The water filter will bypass to the drain pan if the filter is stopped up. (If you have a filter that is. I don't think It could have anything to do with the work you did.
  #3 (permalink)
Old 06-10-2009, 02:47 PM
Junior Member
Default
Thanks WoodChuckie. I do have a filter, but water flows okay from the water dispenser. Would the bypass flow go through the main drain pipe that I see on the back, bottom side of the unit?
J
  #4 (permalink)
Old 06-10-2009, 03:20 PM
Hardcore DIY'er
APP Volunteer
Default
I don't think It would come out the drain tube if it was a leaky water line. See if your diagram will help. >KENMORE | Model #10652544101 | SIDE-BY-SIDE REFRIGERATOR | ********************************.com
  #5 (permalink)
Old 06-11-2009, 08:45 AM
Junior Member
Default
Thanks. I'd looked at the diagram, earlier, but didn't get a whole lot from it. Once I remove the back panel and turn the water source on again, I hope it will be obvious where the leak is.
  #6 (permalink)
Old 07-03-2009, 09:00 AM
Junior Member
Default
woodchuckie,
I'm finally getting to this. Should the main galvanized metal panel/cover on the back come off? If so, can you advise how as it appears to be tucked under the edge on the top and sides. Or should the internal water lines all be visible when the lower ventilation panel in the rear is removed? TIA
  #7 (permalink)
Old 07-03-2009, 10:17 AM
Junior Member
Default
More info... just turned the water back on and with extra eyes observing from the front, back and inside, we see a slow but steady (every 10 seconds or so) drip at the back of the water filter housing and the two front-most of the two tubes and the grey connector.
The water filled the ice maker tray with an appropriate amount of water and did not overfill. I'm going to observe a defrost cycle to see if I can again see water streaming out of the drain pipe into the pan as I did when the problem first happened.
So, at least I know I need to fix the connection(s) to the water filter housing. Hopefully this is pretty straight forward.
  #8 (permalink)
Old 07-03-2009, 10:24 AM
Junior Member
Default
woodchuckie,
Can you advise if the housing can be repaired or do I need to replace it? I see it is leaking from the bottom of the body, not just from the connection.
For now, I've removed the water filter and confirmed that it doesn't leak, even from the connection which dripped verry slowly when the water was first turned on. Perhaps it is the o-rings on the filter? I'm going to replace the filter to see if that solves the problem. If it doesn't, then I'll fix or replace the housing.
TIA
  #9 (permalink)
Old 07-03-2009, 11:16 AM
Hardcore DIY'er
APP Volunteer
Default
You may can repair it with an epoxy made for the same material. It may be worth a try since the new part cost 50 dollars.
  #10 (permalink)
Old 07-04-2009, 09:23 AM
Junior Member
Default
Thanks. If it still leaks with the new filter, I'll repair or replace the housing. I left the water source on overnight and no water on the floor. I'm wondering if you were right on with your initial idea that the filter was stopped-up.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Sears Kenmore side by side runs 24/7 freezer cold but not freezing patrickmcglashan Refrigerator & Freezer Repair 0 02-08-2010 12:18 PM
Water dispenser line frozen in door-GE side/side JenniferL Refrigerator & Freezer Repair 0 09-27-2009 11:46 AM
kenmore fridge freezer side by side blowing warm widgitfix Refrigerator & Freezer Repair 3 03-27-2009 01:46 PM
Kenmore side by side took power surge, freezer fan not running rsgators2001 Refrigerator & Freezer Repair 6 02-23-2009 12:01 PM
Kenmore Side By Side - Door Water Dispenser Leaks FIXITMOM Refrigerator & Freezer Repair 0 09-24-2008 07:03 AM
