Discuss
Kenmore Freezer warm sides / not freezing
 in
Refrigerator & Freezer Repair
My (Just barely 5 year old) Kenmore Frost Free Heavy Duty Commercial Upright Freezer temp alarm started going off. Sure
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kenmore Freezer warm sides / not freezing
  #1 (permalink)
Old 06-09-2009, 06:16 PM
Junior Member
jbade is on a distinguished road
Default Kenmore Freezer warm sides / not freezing
Model Number: 23024 ???   Brand: Kenmore   Age: 5 - 10 years
Sure enough stuff on top and the door is a bit soft.
I made sure the door was closed all the way and pushed the Quick Free button. (cleared the alarm as well)
I heard the compressor and felt cold air so I thought maybe the door didn't fully close.
Next morning the alarm was going off again.
Tempature seemed about the same, stuff on the bottom was still rock hard frozen (technical term... LOL)
So I did the same thing.. reset the alarm.. turned on and off the Quick Freeze. Then left for work.. hoping for the best.
Came home today.. Still some stuff like the Popsicles were not frozen but all in all it was much better.. Also NO alarm this time.
Sides are still quite warm, Looked at the lines going into the compressor, the HOT return line is very hot and will burn my hand.. (as well as the compresser itself.. the cold side, at least what I think is the cold side isn't all that cold, but not hot either. Not sure if this helps.
It is humid in the basement.. and there is a lot of moisture in the freezer.. at least at first.. not a lot of ice on the bottom of the shelves or tops of things in the freezer..
Taking temp readings with a digital surface thrermometer.
Top inisde back wall where cold air blows out 5 degrees F.
Bottom back wall 10 degrees
Front inside door around 20-25..
I felt the outside sides and they seem to be cooler to the touch.. current reading was around 95 degrees..
Any thoughts?
Thanks,
Jeff
Ads By Google
Related Models
Jenn-Air 23075 Surface Unit - Gas
Jenn-Air 23079 Surface Unit - Gas
Jenn-Air 2320ERS Surface Unit - Ddraft Ele
Whirlpool 2323W0A
Whirlpool 2323^0A
Whirlpool 2324W0A
Jenn-Air 2325ERS Surface Unit - Ddraft Ele
Whirlpool 2326W0A
Whirlpool 2326^0A
Whirlpool 2328W00
Whirlpool 2328^00
Kenmore 233.50303200  RANGE HOOD
Kenmore 233.50363200  RANGE HOOD
Kenmore 233.50941590  RANGE HOOD
Kenmore 233.51041590  RANGE HOOD
Kenmore 233.5108010  KENMORE RANGE HOOD
Kenmore 233.5108011  KENMORE RANGE HOOD
Kenmore 233.5108012  KENMORE RANGE HOOD
Kenmore 233.5108910  RANGE HOOD
Kenmore 233.5108911  RANGE HOOD
Kenmore 233.51141590  RANGE HOOD
Kenmore 233.51345590  RANGE HOOD
Kenmore 233.5137810  KENMORE RANGE HOODS
Kenmore 233.5137812  KENMORE RANGE HOOD
Kenmore 233.5137813  KENMORE RANGE HOOD
Kenmore 233.5138910  KENMORE RANGE HOOD
Kenmore 233.5138911  RANGE HOOD
Kenmore 233.5138912  RANGE HOOD
Kenmore 233.51545590  RANGE HOOD
Kenmore 233.51645590  RANGE HOOD
Kenmore 233.5167810  KENMORE RANGE HOOD
Kenmore 233.5167811  KENMORE RANGE HOOD
Kenmore 233.5167812  KENMORE RANGE HOOD
Kenmore 233.5168910  KENMORE RANGE HOOD
Kenmore 233.5168911  RANGE HOOD
Kenmore 233.5168912  KENMORE RANGE HOOD
Kenmore 233.5168913  RANGE HOOD
Kenmore 233.51745590  RANGE HOOD
Kenmore 233.8498250  MICRO-HOOD
Kenmore 233.8498450  MICRO-HOOD
Kenmore 23351840590 RANGE HOOD
Kenmore 23351841590 RANGE HOOD
Kenmore 23351848590 RANGE HOOD
Kenmore 2335188410 KENMORE RANGE HOOD
Kenmore 2335188411 KENMORE RANGE HOOD
Kenmore 2335188610 KENMORE RANGE HOOD
Kenmore 2335188910 KENMORE RANGE HOOD
Kenmore 2335188911 RANGE HOOD
Kenmore 233518910 RANGE HOOD
Kenmore 23351898 RANGE HOOD
Kenmore 23351899 RANGE HOOD
Kenmore 23352045590 RANGE HOOD
Kenmore 23352052002 RANGE HOOD
Kenmore 2335207810 KENMORE RANGE HOOD
Kenmore 2335207811 KENMORE RANGE HOOD
Kenmore 2335208390 KENMORE RANGE HOOD
Kenmore 2335208510 KENMORE RANGE HOOD
Kenmore 2335208610 KENMORE RANGE HOOD
Kenmore 2335208910 RANGE HOOD
Kenmore 2335209690 RANGE HOOD
Kenmore 2335209950 RANGE HOOD
Kenmore 23352145590 RANGE HOOD
Kenmore 2335217810 KENMORE RANGE HOOD
Kenmore 2335217811 KENMORE RANGE HOOD
Kenmore 2335218510 KENMORE RANGE HOOD
Kenmore 2335218610 KENMORE RANGE HOOD
Kenmore 2335218910 RANGE HOOD
Kenmore 2335219690 RANGE HOOD
Kenmore 2335219950 RANGE HOOD
Kenmore 23352303200 RANGE HOOD
Kenmore 23352345590 RANGE HOOD
Kenmore 23352363200 RANGE HOOD
Kenmore 2335237810 RANGE HOOD
Kenmore 2335237811 RANGE HOOD
Kenmore 2335238510 RANGE HOOD
Kenmore 2335238910 RANGE HOOD
Kenmore 2335239590 RANGE HOOD
Kenmore 23352423200 RANGE HOOD
Kenmore 23352445590 RANGE HOOD
Kenmore 2335247810 RANGE HOOD
Kenmore 2335247811 RANGE HOOD
Kenmore 2335248510 RANGE HOOD
Kenmore 2335248910 RANGE HOOD
Kenmore 2335249590 RANGE HOOD
Kenmore 23353245590 RANGE HOOD
Kenmore 23353345590 RANGE HOOD
Kenmore 2335337810 KENMORE RANGE HOOD
Kenmore 2335337811 KENMORE RANGE HOODS
Kenmore 2335337812 KENMORE RANGE HOOD
Kenmore 2335337813 KENMORE RANGE HOOD
Kenmore 2335338910 KENMORE RANGE HOOD
Kenmore 2335338911 RANGE HOOD
Kenmore 2335338912 RANGE HOOD
Kenmore 23354060591 KENMORE RANGE HOOD
Kenmore 23354065591 KENMORE RANGE HOOD
Kenmore 23354066591 KENMORE RANGE HOOD
Kenmore 23354069591 KENMORE RANGE HOOD
Kenmore 23354363200 RANGE HOOD
Kenmore 2335437810 KENMORE RANGE HOOD
Kenmore 2335437811 KENMORE RANGE HOODS
Kenmore 2335447810 KENMORE RANGE HOOD
Kenmore 2335447811 KENMORE RANGE HOODS
Kenmore 23355012000 RANGEHOOD
Kenmore 23355013000 RANGEHOOD
Kenmore 23355014000 RANGEHOOD
Kenmore 23355017000 RANGE HOOD
Kenmore 23355019000 RANGEHOOD
Kenmore 23355112000 RANGEHOOD
Kenmore 23355113000 RANGEHOOD
Kenmore 23355114000 RANGEHOOD
Kenmore 23355117000 RANGE HOOD
Kenmore 23355119000 RANGEHOOD
Kenmore 23355212000 RANGEHOOD
Kenmore 23355213000 RANGEHOOD
Kenmore 23355214000 RANGEHOOD
Kenmore 23355217000 RANGE HOOD
Kenmore 23355219000 RANGEHOOD
Kenmore 23355345590 RANGE HOOD
Kenmore 2335537910 RANGE HOODS
Kenmore 2335537911 KENMORE RANGE HOODS
  #2 (permalink)
Old 06-09-2009, 08:52 PM
Hardcore DIY'er
APP Volunteer
woodchuckie is on a distinguished road
Default
Check and make sure the condenser fan near the compressor is running.
If it's running check for ice on the evaporator coils in the freezer blocking the air flow. Usually behind the back panel in the freezer. This would be a defrost problem. Post your model number for diagrams. Model Number Locator
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer Freezing Refer Warm carvelli Refrigerator & Freezer Repair 6 08-25-2009 07:04 AM
fridge is warm, freezer still freezing budd Refrigerator & Freezer Repair 2 07-10-2009 09:16 PM
coils freezing up in freezer and frig temps warm dhofer Refrigerator & Freezer Repair 3 06-02-2009 06:01 PM
both sides freezing toff Refrigerator & Freezer Repair 1 12-06-2008 08:13 AM
Freezer blows cool but not freezing and refrig is warm Angelicas Refrigerator & Freezer Repair 2 08-08-2007 08:06 PM
