Our ice maker quit making ice and found that the front gear was broken. I pulled the part number off of the white label and found a replacement on your site. I ordered AP4360346 as it came up on my search of 626662 and looked just like our existing one. I received the part and installed with no problems. We are now getting ice again but it seems like the fridge never turns off now (or at least the below fan) and has an occasional relay click sound that turns on and off after about 15 seconds or so and repeats about every 4 min. When it happens it must be pulling some power because the lights in the fridge seems to dim. Concerned I did more research it seems that although the ice maker looks the same it actually did not show that it was compatible with my fridge. Could the ice maker I purchased be causing the changes I seem to be experiencing now? Should I buy the other ice maker (or motor assembly) that shows to be compatible with my fridge or is this all in my mind? Is this a problem I should be concerned about? Thanks James
