barneyrubble
#1 Posted : Monday, June 8, 2009 6:16:00 PM(UTC)
barneyrubble
The pc control board was replaced by a service tech and the problem remained. the freezer frosts up and stops air flow through the baffle to the refrigerator. The freezer will not defrost. After the service tech finished and gave up, I took the shroud off the control board and noticed that a plastic connector with a brown wire and a pink wire was hanging with no connection. these wires go to the bimetal switch on the evaporator coils and also to the defrost element. There is no obvious place to plug the connector into under the shroud in the refrigerator control section. What do these wires connect to? I think that they should connect to a power source or timer to run the defrost element but I can't see where they connect.
#2 Posted : Tuesday, June 9, 2009 6:12:15 AM(UTC)
Replacement parts for WHIRLPOOL KSCS25FJSS00 | AppliancePartsPros.com
Here is the tech sheet
https://www.servicematters.com/d...0Sheet%20-%202199974.pdf
Nothing. They are there as a service aid. If you try to force a defrost using the diagnostics and the thermostat is open, you put a short/jumper across this connector and now the heater should heat up.
Could also be used to check the thermostat. If the coils are frozen up and you try run the defrost but the element does not heat up, unplug the unit, install a jumper in this plug. Plug the unit in and try to force a defrost again, if the element heats up then the defrost thermostat needs replacing.
barneyrubble
#3 Posted : Tuesday, June 9, 2009 9:50:06 AM(UTC)
barneyrubble
Originally Posted by: denman Go to Quoted Post
denman, thanks for the wiring diagram and other info on the dummy plug. The defrost element does not warm up even with the jumper in place. I know that the element is good because i wired 110 directly to it and it warmed right up. I put the fridge into test mode and the defrost element still will not warm up. As I mentioned, I have replaced the pc control board twice and the problem persists. Is there any chance that one of the thermistors is the culprit?
#4 Posted : Tuesday, June 9, 2009 11:42:58 AM(UTC)
I would doubt that the thermistor would cause a defrost problem especially since the unit seems to operate OK till the evaporator coils ice up.
You may have a broken wire somewhere in the circuit.
You will need a meter to find out if this is the cause.
Freezer will not defrost (Refrigerator & Freezer Repair)
by todhurd 9/26/2013 11:54:42 AM(UTC)
Freezer will not Defrost (Refrigerator & Freezer Repair)
by friendlytx2 4/14/2012 10:36:49 AM(UTC)
freezer will not defrost (Refrigerator & Freezer Repair)
by mph151 7/23/2010 8:41:43 AM(UTC)
by mrnonutz 6/16/2010 8:17:10 AM(UTC)
by MarcusPizzorno 10/26/2009 11:35:52 AM(UTC)
Frigidaire: Freezer will not Defrost (Refrigerator & Freezer Repair)
by dbolan 4/28/2009 5:06:19 AM(UTC)
