The control box display has disappeared and the fridge is not working. The wiring harness is connected at the control box and all of the connections to the motherboard are secure.There is 120 volts AC at the terminals to the motherboard. The compressor and fan do not operate. How do I test the motherboard or the temperature board to determine where the problem is located at. Which wires on the harness from the motherboard carry the 13VDC? Will the fridge work with a bad temp board? Well, this looked like a great way to post and get some great advice.....Little did I know that after three days, not one reply from those in the know. What a waste of time. Three days, no refigerator, and no help!
