Discuss
Kitchenaid Icemaker Not Working
 in
Refrigerator & Freezer Repair
I've seen a number of different posts on this issue, and none hit my topic directly. My ice maker stopped
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kitchenaid Icemaker Not Working
  #1 (permalink)
Old 06-08-2009, 03:00 PM
Junior Member
Doug_dallas is on a distinguished road
Default Kitchenaid Icemaker Not Working
Model Number: KSRB25FKSS03   Brand: Kitchen Aid   Age: 5 - 10 years
I've seen a number of different posts on this issue, and none hit my topic directly. My ice maker stopped working. In reviewing the "Modular Ice Maker & Ice Level Detector Service Sheet" I find a clue; the Icemaker Diagnostics Procedure indicates if the Icemaker's light is Blinking twice followed by a 1 second delay (which it is) that it is one of two causes: 1) the flapper door on the emitter is blocking the beam; or 2) the optics are faulty. Next steps are to disconnect the power supply (which I interpret as unplug the refrigerator) I'm instructed to "3. Slide the Icemaker Out. Remove Cover." I am unable to get the ice maker out. What is the trick? If there are additional tricks beyond what the "service sheet" says I'd appreicate any insight on those issues as well. Any and all help appreciated.
Ads By Google
Related Models
Whirlpool KSRB25FKSS03 Refrigerator
Whirlpool KSRB25FKSS04 Refrigerator
Whirlpool KSRB25FKSS14 Refrigerator
Whirlpool KSRB25FNSS00 Refrigerator
Whirlpool KSRB25FRBX00 Refrigerator
Whirlpool KSRB25FRBX01 Refrigerator
Whirlpool KSRB25FRBX02 Refrigerator
Whirlpool KSRB25FTBX00 Refrigerator
Whirlpool KSRB25QABL00
Whirlpool KSRB25QABL01
Whirlpool KSRB25QABL10
Whirlpool KSRB25QABL11
Whirlpool KSRB25QDBL00
Whirlpool KSRB25QDBL01
Whirlpool KSRB25QDBL02
Whirlpool KSRB25QFBL00
Whirlpool KSRB25QFSS00
Whirlpool KSRB25QGBL00
Whirlpool KSRB25QGBL01
Whirlpool KSRB25QGSS00
Whirlpool KSRB25QGSS01
Whirlpool KSRB25QWAL02
Whirlpool KSRB25QWWH02
Whirlpool KSRB25QXAL00
Whirlpool KSRB25QXAL10
Whirlpool KSRB25QXBL10
Whirlpool KSRB25QXBL11
Whirlpool KSRB25QXWH00
Whirlpool KSRB25QXWH10
Whirlpool KSRB27FGBL00
Whirlpool KSRB27FGSS00
Whirlpool KSRB27FGWH00
Whirlpool KSRB27FHBL00
Whirlpool KSRB27FHBL01
Whirlpool KSRB27FHBL02
Whirlpool KSRB27FHBL03
Whirlpool KSRB27FHBL04
Whirlpool KSRB27FHBL05
Whirlpool KSRB27FHBT01
Whirlpool KSRB27FHBT02
Whirlpool KSRB27FHBT03
Whirlpool KSRB27FHBT04
Whirlpool KSRB27FHBT05
Whirlpool KSRB27FHSS00
Whirlpool KSRB27FHSS01
Whirlpool KSRB27FHSS02
Whirlpool KSRB27FHSS03
Whirlpool KSRB27FHSS04
Whirlpool KSRB27FHSS05
Whirlpool KSRB27FHWH00
Whirlpool KSRB27FHWH01
Whirlpool KSRB27FHWH02
Whirlpool KSRB27FHWH03
Whirlpool KSRB27FHWH04
Whirlpool KSRB27FHWH05
Whirlpool KSRB27QABL04
Whirlpool KSRB27QABL05
Whirlpool KSRB27QABL06
Whirlpool KSRB27QABL07
Whirlpool KSRB27QABL10
Whirlpool KSRB27QABL11
Whirlpool KSRB27QDBL00
Whirlpool KSRB27QDBL01
Whirlpool KSRB27QDBL02
Whirlpool KSRB27QFBL00
Whirlpool KSRB27QFSS00
Whirlpool KSRB27QGBL00
Whirlpool KSRB27QGBL01
Whirlpool KSRB27QGSS00
Whirlpool KSRB27QGSS01
Whirlpool KSRB27QWAL00
Whirlpool KSRB27QWWH00
Whirlpool KSRB27QXAL00
Whirlpool KSRB27QXBL00
Whirlpool KSRB27QXBL01
Whirlpool KSRB27QXWH00
Whirlpool KSRC22DAAL00
Whirlpool KSRC22DAWH00
Whirlpool KSRC22DBAL00
Whirlpool KSRC22DBAL01
Whirlpool KSRC22DBWH00
Whirlpool KSRC22DBWH01
Whirlpool KSRC22DXAL00
Whirlpool KSRC22DXWH00
Whirlpool KSRC22KAAL00
Whirlpool KSRC22KAWH00
Whirlpool KSRC22KBAL00
Whirlpool KSRC22KBAL01
Whirlpool KSRC22KBWH00
Whirlpool KSRC22KBWH01
Whirlpool KSRC22KXAL00
Whirlpool KSRC22KXWH00
Whirlpool KSRC25DAAL01
Whirlpool KSRC25DAWH01
Whirlpool KSRC25DBAL00
Whirlpool KSRC25DBWH00
Whirlpool KSRC25DXAL10
Whirlpool KSRC25DXAL11
Whirlpool KSRC25DXWH10
Whirlpool KSRC25DXWH11
Whirlpool KSRD22FKBL03 Refrigerator
Whirlpool KSRD22FKBL04 Refrigerator
Whirlpool KSRD22FKBL14 Refrigerator
Whirlpool KSRD22FKBL15 Refrigerator
Whirlpool KSRD22FKBL16 Refrigerator
Whirlpool KSRD22FKBT01
Whirlpool KSRD22FKBT02
Whirlpool KSRD22FKBT03 Refrigerator
Whirlpool KSRD22FKBT04 Refrigerator
Whirlpool KSRD22FKBT14 Refrigerator
Whirlpool KSRD22FKBT15 Refrigerator
Whirlpool KSRD22FKBT16 Refrigerator
Whirlpool KSRD22FKSS03 Refrigerator
Whirlpool KSRD22FKSS04 Refrigerator
Whirlpool KSRD22FKSS14 Refrigerator
Whirlpool KSRD22FKSS15 Refrigerator
Whirlpool KSRD22FKSS16 Refrigerator
Whirlpool KSRD22FKST15 Refrigerator
Whirlpool KSRD22FKST16 Refrigerator
Whirlpool KSRD22FKST17 Refrigerator
  #2 (permalink)
Old 06-08-2009, 05:50 PM
Hardcore DIY'er
APP Volunteer
woodchuckie is on a distinguished road
Default
On the diagram it looks like there are two screws on the top to loosen and probably one on the bottom. after loose the ice maker should lift off the bracket and you can unplug the wiring harness. http://www.appliancepartspros.com/se...ptc664w38q.gif
  #3 (permalink)
Old 06-08-2009, 06:24 PM
Junior Member
Dough_dallas is on a distinguished road
Quote:
Thanks for the diagram. Is there a key to the numbers as well? In regard to the wiring harness, are you saying I don't need to unplug the refrigerator before removing the icemaker? I've scanned the document I'm referencing so you can see what I'm seeing. http://home.roadrunner.com/~drharden/KitchenAir-Icemaker-Service-Sheet.pdf
  #4 (permalink)
Old 06-08-2009, 09:07 PM
Hardcore DIY'er
APP Volunteer
Default
The way I read it I believe you're supposed to unplug the refrigerator.
  #5 (permalink)
Old 06-09-2009, 08:09 AM
Junior Member
Default
Okay - Removed Icemaker is instructed. Put jumper in and removed; reconnected power, reinstalled, shut door for 5 seconds and red light still blinking. Repeated all of the above but this time left the jumper in place. Red light went out. Repeated all of the above to remove jumper. Red light blinking again (2 blinks followed by 1 second, repeat).
I therefore conclude, someone please confirm, that the optics are bad. Parts search for optics turns up nothing. I find the part below which I believe is what I need. Will someone please confirm. Thanks.
Refrigerator p.C. Board kit - Kit includes emitter and receiver icemaker control.
Part Number: AP3137510 made by WHIRLPOOL
Last edited by Dough_dallas : 06-11-2009 at 04:04 PM. Reason: Made Progress now need to confirm part
  #6 (permalink)
Old 06-12-2009, 11:36 PM
Junior Member
bob20544 is on a distinguished road
Default
Quote:
Your problem is more likely in the Optics Boards(Emitter and Receiver) which are on each side wall of the freezer(where the blinking light is is the emitter, and on the opposite wall is the receiver). When you press on the emitter flapper door to unblock the optics beam, the flashing lite should change to steadily on. If it continues blinking, the optics boards should be what should be replaced(a simple task). I have the same problem, and will be ordering them myself. About $78 or so. Bob
  #7 (permalink)
Old 06-22-2009, 09:42 AM
Junior Member
Default
Okay - Ordered & Received the Optics board (Emitter and Receiver). Based on the instructions with that, the Optics board does not need replacing. When I went through the steps it suggested, and I press on the emitter flapper door to unblock the optics beam the flashing lite does change to a stead on. So now what? I need to return the parts i ordered and now I need help figuring out what is wrong with the ice maker. Need help. Frustration setting in, about to abandon the DIY option.
  #8 (permalink)
Old 06-23-2009, 11:24 AM
Junior Member
Default
Well, I installed new optics boards, and my problem is fixed. Your only option is to replace the Ice Maker-nothing else left perse. Good Luck.
Bob
  #9 (permalink)
Old 06-25-2009, 02:19 PM
Junior Member
Sears Appliance Repairman just left. Problem identified. Need new MOTOR-MOD. Good news is the part is less expensive here from AppliancePartsPros.com than from Sears.
  #10 (permalink)
Old 06-25-2009, 08:09 PM
Junior Member
Default
Well, hope Sears didn't gouge you too badly for the call.
Replacing the icemaker would have fixed it also, and would have included all the other icemaker parts for about $50 more. However, it's fixed;that's what matters.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid Icemaker not working jayconnor Refrigerator & Freezer Repair 41 07-10-2012 09:35 PM
Kitchenaid Icemaker replaced, Still not working slomo242 Refrigerator & Freezer Repair 6 05-14-2010 04:06 PM
KitchenAid Icemaker not working joescott0202 Refrigerator & Freezer Repair 0 02-12-2010 10:37 AM
Kitchenaid stand alone icemaker not working ossiv99 Refrigerator & Freezer Repair 0 01-26-2010 04:48 PM
kitchenaid icemaker not working dragon123 Refrigerator & Freezer Repair 0 12-30-2009 12:40 PM
