Discuss
Water does not flow
 in
Refrigerator & Freezer Repair
Okay just hooked up my new fridge. The water does not get past some kind of an electric valve manifold.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Water does not flow
  #1 (permalink)
Old 12-21-2007, 01:00 AM
Lofthouse Lofthouse is offline
Junior Member
Lofthouse is on a distinguished road
Default Water does not flow
Model Number: gd5nvaxsa01   Brand: Whirlpool   Age: Less than 1 year
Okay just hooked up my new fridge. The water does not get past some kind of an electric valve manifold. There is some circuitry and about 6 wires going to it. I have tried the ice maker and water dispenser multiple times and over a period of time. Bottom line is the valve is not activating to let it flow. I found the valve mechanism for sale on this site but I am unsure this will fix the problem. I still wonder if there is some kind of signal that is not making its way to the unit or if it is the unit itself. Any suggestions would be helpful. Thanks in advance.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-21-2007, 03:42 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
If the fridge is new - don't do anything and call the Whirlpool.
It's under the warranty.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Standpipe size and drain flow rate suntzujr Washer Repair 1 02-12-2008 01:01 PM
Insuffcient gas flow vornato Oven Repair (including Ranges and Cooktops) 4 12-27-2007 06:05 AM
Thermador Cooktop - burner sparks but no gas flow dmullerd Oven Repair (including Ranges and Cooktops) 2 11-25-2007 07:01 PM
water flow valve BRAND001 Washer Repair 0 07-23-2007 08:05 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
