Discuss
Freezer not freezing
 in
Refrigerator & Freezer Repair
Freezer will freeze a cup of water but will not get cold enough to freeze anything else. Doesnt sound like
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer not freezing
  #1 (permalink)
Old 11-22-2011, 01:24 PM
Pop Pop is offline
Junior Member
Pop is on a distinguished road
Default Freezer not freezing
Model Number: ars9169as   Brand: Amana   Age: 5 - 10 years
Freezer will freeze a cup of water but will not get cold enough to freeze anything else. Doesnt sound like the compressor is kicking on. Is there a control switch down there I can test? I live in Calif. and the repair person is trying to get me to buy a new compressor and charge it for $680, thats without looking at it. There has to be a relay I can try for a few bucks before I have to go to this extreme. Moneys tight, has to be a better way.
Ads By Google
Related Models
Amana ARS9169AS Ref - SXS/I&W
Amana ARS9265BB  Ref - SXS/I&W
Amana ARS9265BC  Ref - SXS/I&W
Amana ARS9265BW  Ref - SXS/I&W
Amana ARS9266BS  Ref - SXS/I&W
Amana ARS9268BB  Ref - SXS/I&W
Amana ARS9268BC  Ref - SXS/I&W
Amana ARS9268BW  Ref - SXS/I&W
Amana ARS9269BS  Ref - SXS/I&W
Amana ARSE664BB Ref - SXS/I&W
Amana ARSE664BC Ref - SXS/I&W
Amana ARSE664BS Ref - SXS/I&W
Amana ARSE664BW Ref - SXS/I&W
Amana ARSE665BB  Ref - SXS/I&W
Amana ARSE665BC  Ref - SXS/I&W
Amana ARSE665BS  Ref - SXS/I&W
Amana ARSE665BW  Ref - SXS/I&W
Amana ARSE667BB Ref - SXS/I&W
Amana ARSE667BC Ref - SXS/I&W
Amana ARSE667BS Ref - SXS/I&W
Amana ARSE667BW Ref - SXS/I&W
Amana ARSE66MBB Ref - SXS/I&W
Amana ARSE66MBC Ref - SXS/I&W
Amana ARSE66MBW Ref - SXS/I&W
Amana ARSE66ZBB  Ref - SXS/I&W
Amana ARSE66ZBC  Ref - SXS/I&W
Amana ARSE66ZBS  Ref - SXS/I&W
Amana ARSE66ZBW  Ref - SXS/I&W
Amana ARSE67RBB  Ref - SXS/I&W
Amana ARSE67RBC  Ref - SXS/I&W
Amana ARSE67RBS  Ref - SXS/I&W
Amana ARSE67RBW  Ref - SXS/I&W
Amana ART1805BC Ref - Top Mount
Amana ART1805BW Ref - Top Mount
Amana ART2105BB Ref - Top Mount
Amana ART2105BC Ref - Top Mount
Amana ART2105BW Ref - Top Mount
Amana ART2107BB Ref - Top Mount
Amana ART2107BC Ref - Top Mount
Amana ART2107BS Ref - Top Mount
Amana ART2107BW Ref - Top Mount
Amana ART2127AB Ref - Top Mount
Amana ART2127AC Ref - Top Mount
Amana ART2127AS Ref - Top Mount
Amana ART2127AW Ref - Top Mount
Amana ART2129ABR Ref - Top Mount
Amana ART2129ACR Ref - Top Mount
Amana ART2129ASR Ref - Top Mount
Amana ART2129AWR Ref - Top Mount
Amana ART2527AB Ref - Top Mount
Amana ART2527AC Ref - Top Mount
Amana ART2527AW Ref - Top Mount
Amana ART5400L Range - Std Mwave Ele
Amana ART5400W Range - Std Mwave Ele
Amana ART6000L Range - S/c S/i Ddraft Gas
Amana ART6000W Range - S/c S/i Ddraft Gas
Amana ART6001L Range - S/c S/i Ddraft Gas
Amana ART6001W Range - S/c S/i Ddraft Gas
Amana ART6002L Range - S/c S/i Ddraft Gas
Amana ART6002W Range - S/c S/i Ddraft Gas
Amana ART6021C Range - S/c S/i Ddraft Gas
Amana ART6021L Range - S/c S/i Ddraft Gas
Amana ART6021W Range - S/c S/i Ddraft Gas
Amana ART6100E Range - S/c S/i Ddraft Gas
Amana ART6100LL Range - S/c S/i Ddraft Gas
Amana ART6100WW Range - S/c S/i Ddraft Gas
Amana ART6110E Range - S/c S/i Ddraft Ele
Amana ART6110LL Range - S/c S/i Ddraft Ele
Amana ART6110W Range - S/c S/i Ddraft Ele
Amana ART6110WW Range - S/c S/i Ddraft Ele
Amana ART6112LL Range - S/c S/i Ddraft Ele
  #2 (permalink)
Old 11-24-2011, 06:23 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Replacement parts for AMANA ARS9169AS REF - SXS/I&W | AppliancePartsPros.com
See the attachment for the tech sheet
Here is a manual
RS1300004 Amana V Series Side-by-Side Refrigerator with Foam-in-Place Doors Service Manual - ApplianceDigest.com
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
It looks like the compressor control is a fairly simple design with a mechanical thermostat and a defrost timer.
Is the condenser/compressor fan running?
It is wired in parallel with the compressor so when it runs the compressor should run.
If it is running below is a link that tells you how to check the compressor and it's start device.
If it is not running then the compressor is probably OK.
So check the temperature set thermostat.
If it and the evaporator/freezer fan are not running you may be stuck in a defrost cycle.
Turn the cam on the defrost timer (Item 12 in Section 11) to see if it will fire up. There should be a hole in the cover to let you do this. Aklso it only turns in one direction.
Appliance Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
__________________
  #3 (permalink)
Old 11-30-2011, 02:16 PM
Pop Pop is offline
Junior Member
Default
Replaced the defrost timer, it wasn't checking out. Still will freeze a container of water but ice cream goes soft. In the front on the bottom the coils are just room temp. Repair guy told me on the phone it will be approx $500 to $725 to fix. I have the dial turned up to the coldest right now and when I turn it off the fans go off. Thanks for helping.
  #4 (permalink)
Old 12-01-2011, 07:26 AM
Senior Expert
APP Volunteer
Default
I am assuming that the compressor is running and that it runs all the time but the unit will not get cold enough.
Remove the cover from inside of the freezer so you can inspect the evaporator coils.
If they are heavily iced/frosted over you have a defrost problem.
If there is just frost in one area (usually where the freon enters the coils) you have a sealed system problem.
Note: this inspection must be done after the compressor has run for a couple hours. If you do it shortly after a defrost cycle then you could come to the wrong conclusion.
This will be an expensive repair. I think this is what the repair person you talked to is thinking is the problem.
Check the warranty on the unit many units have a longer sealed system warranty.
Often it makes more sense to invest those dollars into a new unit.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
freezer not freezing carolb4 Refrigerator & Freezer Repair 1 06-25-2011 04:05 AM
Fridge freezing, Freezer over-freezing breistl77 Refrigerator & Freezer Repair 0 12-29-2009 09:12 AM
GE - fridge freezing in drawers, freezer not freezing at top, but coils frozen over jaxcarlson Refrigerator & Freezer Repair 0 12-01-2009 09:42 AM
GE fridge/freezer freezer is defrosting and not freezing anymore booomer Refrigerator & Freezer Repair 1 04-06-2009 05:32 AM
Sub Zero 201 FD Freezer is not freezing and coils are frosting over/freezing up badace Refrigerator & Freezer Repair 1 12-02-2007 09:54 AM
