Discuss
Ice Maker Overfilling
 in
Refrigerator & Freezer Repair
Ice Maker overfills with water causing thick cubes. Cubes sometimes do not drop due to cube thickness.Water spills over
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice Maker Overfilling
  #1 (permalink)
Old 12-20-2007, 04:46 AM
Gene D Gene D is offline
Junior Member
Gene D is on a distinguished road
Default Ice Maker Overfilling
Model Number: SRD25S5W   Brand: Amana   Age: 5 - 10 years
Ice Maker overfills with water causing thick cubes. Cubes sometimes do not drop due to cube thickness.Water spills over into ice container while filling. Tried changing inlet water valve and this did not solve the issue.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-20-2007, 06:41 AM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
you may be able to remove cover from icemaker and turn down the amount of time the icemaker calls for water ...there is usually a philips screw mounted sideway kind of in the upper right corner and you want to turn in a 1/4 turn to the "-" sign...
__________________
regards
jim
  #3 (permalink)
Old 12-20-2007, 02:47 PM
Junior Member
Default
Jim:
Found what looks like a plastic screw with a slot in the location you mentioned after removing the cover. There is no "-" or "+" so I tried turning it counterclockwise. If anything, it seemed worse so I turned it back to original and then clockwise a good 1/2 turn. I will let you know how I make out.
Gene D
  #4 (permalink)
Old 12-21-2007, 06:34 AM
Junior Member
Default
Jim:
Adjusting this screw did not make a difference either way. Could it be something else besides the ice maker itself or the water fill valve?
Gene D
  #5 (permalink)
Old 12-21-2007, 07:07 AM
Senior Expert
APP Volunteer
Default
possibly a watervalve situation where it is not seating properly, but somewhat unlikely ... try turning the screw another 1/2 to 3/4 turn clockwise ...
__________________
regards
jim
  #6 (permalink)
Old 12-21-2007, 08:32 AM
Junior Member
Default
tried turning clockwise 1 full turn, still spill water over. It does not seem as if it will go in any more (clicks). Should I try counterclockwise again?
  #7 (permalink)
Old 12-21-2007, 09:33 AM
Senior Expert
APP Volunteer
Default
ok.. is this the screw ( metal ) within the center of a large plastic gear ?
__________________
regards
jim
  #8 (permalink)
Old 12-21-2007, 11:47 AM
Junior Member
Default
No its a plastic screw on the outside of the icemaker on the side that you see when you look inside the freezer after removing the cover. Nothing elses is on the outside of the icemaker. I had it out of the freezer. You need to remove 3 screws to get inside where the motor is. Is there anything to adjust in there?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
defrost drain pan repeatedly overfilling j13 Refrigerator & Freezer Repair 5 12-08-2007 03:20 AM
Maytag Neptune Washer overfilling badace Washer Repair 0 12-01-2007 11:08 PM
Overfilling Washing Machine ackerberg Dishwasher Repair 2 11-25-2007 09:19 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
