Mevdawg
#1 Posted : Sunday, November 20, 2011 12:46:16 PM(UTC)
Mevdawg
Icemaker has been leaking water underneath ice tray and freezing on top of motor and leaving an ice block between tray and motor already replaced inlet valve due to research from this website worked for awhile thought it was fixed, started again and now quit working altogether. Any suggestions?
ScottEge
#2 Posted : Monday, November 21, 2011 10:51:16 AM(UTC)
ScottEge
Check pressure at water dispensor. You should get 5oz. minimum in 5 seconds. Low water pressure is the number one cause of weeping valves. If the supply water line has a self piercing saddle valve ask a plumber to put a 1/4" inlet saddle valve on the cold water pipe.
Mevdawg
#3 Posted : Tuesday, November 22, 2011 8:21:01 AM(UTC)
Mevdawg
I can't check that cause i have no water at the dispenser either, there is a self piercing inlet valve and it is open, and this has been happening off and on too w/ no water. Do they have to cut the pipe to install a 1/4" inlet valve that you spoke of ? Thank you for your response !!!
ScottEge
#4 Posted : Wednesday, November 23, 2011 5:40:04 AM(UTC)
ScottEge
No typically after they shut the water off and remove self piercing valve. the hole can be drilled the correct size and install correct valve.
Icemaker inoperative (Refrigerator & Freezer Repair)
by mtmo3510 2/26/2013 10:37:54 AM(UTC)
Icemaker inop (Refrigerator & Freezer Repair)
by 66 2dr post 11/15/2011 11:31:53 AM(UTC)
Icemaker Inoperative (Refrigerator & Freezer Repair)
by ottenw 9/30/2010 2:09:07 PM(UTC)
