I've got a Kenmore Elite side-by-side. The freezer works great - too great! Ice cream is a solid block. It seems that the freezer motor/fan runs constantly. The defrost is working just fine, except it's so cold that the defrosted water freezes in the drain and then fills the bottom of the compartment as a block of ice, so I clear it out about once a week.
I've already replaced the main control board and the RC thermistor. Even though the diagnostics show "1" for the FC thermistor, I'm going to try replacing it next. Any other ideas?
Thanks!
