Discuss
freezer gasket not sealing
 in
Refrigerator & Freezer Repair
I have ice building up inside the freezer on the bottom of the compartment. I replaced the door gasket and
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » freezer gasket not sealing
  #1 (permalink)
Old 06-04-2009, 12:02 PM
Junior Member
clarkl is on a distinguished road
Default freezer gasket not sealing
Brand: Jenn-Air   Age: 5 - 10 years
I have ice building up inside the freezer on the bottom of the compartment. I replaced the door gasket and feel certain this was the problem because the top right and left corners of the door had black sediment ( probably from sucking air ), and the inside of the door between the compartment and the outer door housing I had ice build up on the upper section of the door. I cleaned up all of the ice build up and installed the new gasket and where the gasket was folded in shipping it is a little deformed and is still not sealing properly. What can I do to help the gasket to lay down and seal this door?
  #2 (permalink)
Old 06-04-2009, 03:10 PM
Senior Member
applianceman is on a distinguished road
Default
Use a heat gun or hair dryer to work out the bad places. Also once you get it in shape rub a thin film of Vaseline on the entire length of the door gasket. For future reference soak the gasket in hot water for a few minutes before attempting to install the gasket this will normally take care of the problem you are having. Refrigerator repair guide
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer door not sealing cbs24 Refrigerator & Freezer Repair 7 07-27-2009 09:14 AM
New gasket installed-door not sealing smcguire2001 Refrigerator & Freezer Repair 0 05-08-2009 05:40 PM
Ice on coils in freezer; Refridge door not Sealing Julie Riggleman Refrigerator & Freezer Repair 2 10-01-2008 07:58 AM
Door not sealing with new gasket brookdoyle Refrigerator & Freezer Repair 2 12-20-2007 09:08 AM
Freezer door not sealing RadRick Refrigerator & Freezer Repair 1 08-08-2007 05:49 PM
