Discuss
Ice Maker fills water but...that's it.
 in
Refrigerator & Freezer Repair
Just what the title said, I can feel the water in the tray but no ice is being made. Thanks
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice Maker fills water but...that's it.
  #1 (permalink)
Old 12-19-2007, 11:23 AM
amati5 amati5 is offline
Junior Member
amati5 is on a distinguished road
Default Ice Maker fills water but...that's it.
Model Number: ED27DS   Brand: Whirlpool   Age: More than 10 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-19-2007, 04:26 PM
kooler kooler is offline
Senior Expert
APP Volunteer
kooler is on a distinguished road
Default temp issues
Place an accurate thermometer in your freezer and note the temp, should be zero or close to it; if there's product inside this freezer then it's it's at the point of thawing if water will not freeze in the ice maker... Any ice cream will be a milk shake by now... Check fan motors inside and out, inspect evaporator in freezer (rear cover) for ice buildup, check thermostat setting... Check for dirty condenser coil underneath fridge... Post back with more info...
__________________
  #3 (permalink)
Old 12-19-2007, 04:56 PM
Junior Member
Default
Thank you for your response. The temp setting was lowered to one level and it's ice now but not ejected. I did some research and it seems mine (whirlpool) is a modular type and can't check the ejector's gear. I just have to buy a new module control. Is it something you can confirm or there is better way to check.
thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
water fills and stops intermittently worldtravelert Washer Repair 0 12-08-2007 10:50 AM
Ice maker not getting water bbrazeal@bellsouth.net Refrigerator & Freezer Repair 0 11-27-2007 04:13 PM
ice maker no water mpmc Refrigerator & Freezer Repair 3 11-07-2007 01:48 PM
washer fills with water then run program cancels Doug Quinn Washer Repair 0 11-03-2007 09:39 PM
Water Is Draining As It Fills jbgreer Washer Repair 2 09-03-2007 11:52 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
