Discuss
Refrigerator Defrost Problems
 in
Refrigerator & Freezer Repair
On this refrigerator, I have replaced the defrost heater, defrost T-stat, and also the main control board. After a
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrigerator Defrost Problems
  #1 (permalink)
Old 12-19-2007, 10:54 AM
Albert M. Albert M. is offline
Junior Member
Albert M. is on a distinguished road
Default Refrigerator Defrost Problems
Brand: GE   Age: 1 - 5 years
On this refrigerator, I have replaced the defrost heater, defrost T-stat, and also the main control board. After a week went by, the refrigerator evaporator was icing up again and not cooling properly. I did some continuity checks, looked for loose connections but found no problems. I did notice while having the freezer section disassembled, there were two thermistor sensors near the evaporator. One sensor was ID on the diagram as #241-it was clamped on the evaporator suction line. I could not locate the other sensor on the diagram but it is located in the bottom left corner of the freezer compartment and seems to sense the air near the bottom of freezer. Does these sensors have to do with the defrost cycle?? If so, how do you replace them??
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-19-2007, 05:43 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hello Albert,
In order to provide the most accurate advise I need the complete model number of the refrigerator.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 12-20-2007, 03:24 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
The pros recommend you replace the freezer fan motor and thermistor at the same time, they come as a kit.
__________________
  #4 (permalink)
Old 12-20-2007, 12:14 PM
Junior Member
Default Refrigerator defrost problems
Gene and richappy,
The make and model is as follows: GE model: GSS25JFMBWW
Please note that the freezer fan motor works fine.
  #5 (permalink)
Old 12-20-2007, 12:23 PM
Junior Member
Default
  #6 (permalink)
Old 12-20-2007, 01:30 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the problem is the evaporator thermistor.
You can find the part location in the attached service manual (pages 55 & 60).
- The part number for the evaporator (and all other) thermistor is
AP3185407
In order to replace it just cut off the old one and install the new thermistor using a wire nuts.
Good luck.
File Type: pdf PSS and GSS refrigerators service manual.pdf (1.68 MB, 20 views)
__________________
  #7 (permalink)
Old 02-10-2008, 03:05 PM
jamesbruins jamesbruins is offline
Junior Member
jamesbruins is on a distinguished road
Default Same problem with same model
Hello. This is my first post on this site, but thanks to you guys, I just fixed my GE dryer yesterday from posts on this very site. Thanks for the money saver! Ok. On to the refridgerator problems. I too have a GE model: GSS25JFMBWW, and am having problems. I just back from a year in Iraq, and my wife said the fridge side was room temp. and the freezer side managed to maintain cool (not cold) We have no food on the fridge side, and things that need to stay cold in the freezer side. I just got done taking the fridge apart, and noticed that that the defrost thermostat had a gap in the plastic (that holds the pink and orange wires) and the metal. The gap had brown burn marks and one side of the thermostat wires broke off the terminal where it was soldered. In reading the forum and other online help, I also checked the defrost heater. I noticed a half melted/burned zip tie hanging from under the heater. I removed the defrost heater. I inspected the heater bulb and the whole thing is black. The ends appear to burned (as when a light bulb burns out).
Am I wrong in thinking that this is basically like a light bulb? Or is the thermostat heater supposed to be black?
I am about to order a new thermostat and defrost heater. Is there anything else I should look into replacing? Do these heaters need to be replaced from time to time? Or is there a possibility that there are further electrical problems that maybe caused a short to fry these items?
Please help. We are living out of two tiny college refridgerators, and are on an obvious small budget. I would gain some serious brownie points with the wife if I can get this fridge up and running the right way soon! Thanks!!
Jim
  #8 (permalink)
Old 02-12-2008, 02:45 AM
Senior Expert
APP Volunteer
Default
I assume your freezer coils where all frozen up from top to bottom. If so, just install a new defrost heater and thermostat plus a new freezer thermistor and everything will be ok. Post back in a week if it gets frosted over again.
__________________
  #9 (permalink)
Old 02-12-2008, 09:46 AM
Junior Member
Default Parts on order
Thanks Richappy. Yes, there was frost from top to bottom. Looking at the new defrost heater, I can definately see that the bulb is supposed to be clear and not black, like mine was when I removed it.
I ordered the 3 parts yesterday and am waiting the delivery by Fedex. I appreciate the help! I will post back either way. I am hoping this takes care of the problem.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator Ice Build Up by Defrost Fan Greg R Refrigerator & Freezer Repair 3 12-18-2007 06:53 AM
Refrigerator water dispenser problems moransm Refrigerator & Freezer Repair 4 10-13-2007 06:28 PM
Refrigerator/freezer problems imthewraith Refrigerator & Freezer Repair 3 09-17-2007 03:28 PM
defrost heater Ashman Refrigerator & Freezer Repair 0 07-31-2007 02:13 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
