Discuss
Freezer compressor not running
 in
Refrigerator & Freezer Repair
Sears Coldspot Freezer 106.724240 The overload/relay is firing off every couple of minutes but is not starting the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer compressor not running
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-19-2007, 07:59 AM
thenninger thenninger is offline
Junior Member
thenninger is on a distinguished road
Default Freezer compressor not running
Model Number: 106.724240   Brand: Sears   Age: More than 10 years
The overload/relay is firing off every couple of minutes but is not starting the compressor. The compressor is very warm, but not hot to the touch. When the relay first kicks in, there is voltage coming off the overload connector to the compressor (lower right pin). After a couple of seconds, the relay sparks and the voltage is removed. Either the overload or the compressor is humming during the time the voltage is applied, i.e. I'm hearing more than just the click from the relay when it shuts off. The overload is a wire wound unit, so I have my doubts that it could be bad, but I could be wrong. The original overload #548836 has been replaced by the manufacturer with an overload/relay using the same part number and requires some rewiring. Before going to that effort, is there any way to determine if it's really the overload or the compressor? As a side note, the defroster timer went bad and got stuck on the compressor cycle. This would have caused me other problems with the defrost, but I'm not sure it would have caused the compressor problem.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-20-2007, 02:11 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
If the item is rather old and has the high horsepower compressor, you can use a 3n1 hard start device on it, worth a try, just make sure you wire in the run capacitor if it has one. Good idea to monitor the current when plugging in. Remember, the run winding is the compressor terminal that the relay coil wire went to. Good luck
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
intermittent compressor jdea Refrigerator & Freezer Repair 3 12-12-2007 06:59 AM
Compressor installation rmdrc Refrigerator & Freezer Repair 1 10-31-2007 02:32 AM
freezer/refrigeratornot cooling, motor running with clicking sound intermittent counterbob20 Refrigerator & Freezer Repair 2 10-07-2007 12:23 PM
Refrig works but freezer is not running cold enough Bill Tagatz Refrigerator & Freezer Repair 1 08-01-2007 05:43 AM
Left side of freezer really hot - running constantly bearlymakinit Refrigerator & Freezer Repair 4 07-30-2007 11:23 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
