Hi, I have a Samsung RFG 297 and the ice-maker is not working. Still under warranty and the same same tech has replaced the ice-maker 3 times. the water dispenser works fine, plenty of volume. pushing the test button on side of ice-maker seems to activate the solenoid breifly but not long enough to fill the tray. It seems that there are 2 solenoids involved, 1 next to the water side and 1 below by the tubing outlet. I was told that there is a sensor in the tray furthest from inlet to tell when tray is full. is the solenoid at fault or the control board (there are 2)?
Thanks for your help Larry
