Discuss
ice maker crushes, no cubes
 in
Refrigerator & Freezer Repair
My Kenmore refrigerator, model 253.5466440A has an in the door ice dispenser and it appears to not be able
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » ice maker crushes, no cubes
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 08-06-2007, 07:18 AM
sfshipley sfshipley is offline
Junior Member
sfshipley is on a distinguished road
Default ice maker crushes, no cubes
Model Number: 253.5466440A   Brand: Kenmore   Age: 1 - 5 years
My Kenmore refrigerator, model 253.5466440A has an in the door ice dispenser and it appears to not be able to deliver cubes. The ice comes out crushed regardless of the setting. I happen to have just come back from being two weeks away, but we had a house sitter who was using it so I don't think it was from lack of use. Any ideas?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-10-2007, 05:09 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
sfshipley
Remove the ice container and the cover for the auger motor. Check the solenoid for continuity. If there is no continuity replace the solenoid. The part number for the new one is AP3965453
If there is continuity remove the wires from the solenoid, attach the power probes from the meter to the wires, set the ice dispenser for the whole cubes and holding the door switch pushed in, push the ice cube release button. It should be 120V measured across solenoid wires. If there is athe proper power replaced the solenoid.
If there is no power then the problem is with the ice dispenser in the door.
Let me know and we will go further.
Good luck.
  #3 (permalink)
Old 08-10-2007, 10:15 PM
Dwain Stewart Dwain Stewart is offline
Junior Member
Dwain Stewart is on a distinguished road
Default Any results yet?
Quote:
I seem to have the same problem. Did you find out what your problem was??
  #4 (permalink)
Old 03-11-2008, 07:20 AM
duane peake duane peake is offline
Junior Member
duane peake is on a distinguished road
Default
I have the same problem and i replaced the solenoid. It still despences only crushed ice. what should i do next?
  #5 (permalink)
Old 03-11-2008, 08:41 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Duane,
What is the model number of the fridge?
__________________
Professional appliance repair services in Orange County, California.
  #6 (permalink)
Old 03-11-2008, 11:05 AM
Junior Member
Default
Quote:
Originally Posted by Gene View Post
Hi Duane,
Gene,
I'll get the model number tonight when i arrive home.
  #7 (permalink)
Old 03-12-2008, 07:43 AM
Junior Member
Default
Gene,
My G.E. refrigerator model number is TFX25JRYD WW, serial number is LR251043.
  #8 (permalink)
Old 03-12-2008, 03:04 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Duane,
Does the solenoid clicks when the ice dispenser calls for a whole cubes?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
