My Whirlpool model #gs5shaxnl00 will not fill with water on its own.checked valve by using jumper wire from the water valve that supplies the water on the door and connected it to the ice maker valve,the valve works.Removed ice maker unit and jumped the thermostat to put in harvest mode the arm moved and it filled with water but it will not eject the ice .Do I need an Ice maker or the sensors on the door? PLEASE HELP ME GENE!!!!!!!
CAN SOMEONE PLEASE HELP ME :confused:
