Greetings!
We have a Summit Refer/Freezer here, made in Brazil. Dimensions: 25"wide x 64" tall x 25" deep, outside dimensions. Item serial number and model number currently can't be found. However, we have a small problem. The light bulb in the refer. box finally burned out. We are having difficulty of finding a replacement. The number on the bulb: SDK 120V 7.5W. The total height of the bulb is: 2". It has a small screw-type base, with the diameter of approx. 1/2" wide. The length of the base is: 1" from shoulder to tip. The glass (if held upside-down) is teardrop shaped. Email: zonofabee ATgmail DOTcom
Can you furnish us information about such an animal, and where we can get one? :confused:
