The unit worked fine until it was turned off for a month or two. Now that it is back on the compressor runs but there are no fans or cold air inside. The ice maker and water dispenser are not working either. I have tried to find online information on what to look for and found this site.
If nothing running, I would tap on the control panel, might have a stuck cold control.
