chuckeburn1
#1 Posted : Wednesday, May 27, 2009 1:54:57 PM(UTC)
chuckeburn1
I have a fridgerator/freezer and it keeps freezing up is the deftost timer bad and if so how do i test this part to make sure it is bad.
Chuck.
woodchuckie
#2 Posted : Wednesday, May 27, 2009 3:01:36 PM(UTC)
woodchuckie
You have a defrost timer, defrost heater and a defrost thermostat. Here's how to check them with a multi tester.Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com You can also test the timer by turning it till it clicks and the fridge/freezer will turn off going into defrost cycle. If the heater then melts the ice on the evaporator, you know the timer is not running. If it doesn't melt it you'll need to check the heater then the thermostat. Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Part 23 on diagram 4 is your timer. Replacement parts for FRIGIDAIRE FRT16NRGD0 | AppliancePartsPros.com
Kenmore refrigerator/freezer issue (Refrigerator & Freezer Repair)
by rgbradley58 1/30/2024 6:32:20 AM(UTC)
GE refrigerator/freezer, freezer compartment gets above freezing, ice cubes melt together (Refrigerator & Freezer Repair)
by CT Redmond 7/2/2023 1:59:53 PM(UTC)
Crosley, model: GS24Y8DV, side by side Refrigerator/Freezer. (Refrigerator & Freezer Repair)
by AeroncaChief 11/9/2022 4:07:46 PM(UTC)
Whirlpool ED2NHGXTL00 Refrigerator/Freezer Won't Stay Cold (Refrigerator & Freezer Repair)
by jrpwjc 1/7/2022 11:42:12 PM(UTC)
TBX18SIGE refrigerator/freezer questions about cardboard (Refrigerator & Freezer Repair)
by Guest 3/28/2021 6:54:00 PM(UTC)
Garage Refrigerator/Freezer Side by Side Maytag (Refrigerator & Freezer Repair)
by Audnbob 2/5/2021 9:52:36 AM(UTC)
LG Refrigerator/freezer clunking (Refrigerator & Freezer Repair)
by mohave.vacationer 11/13/2020 7:42:16 PM(UTC)
Kenmore 795.76203.901 refrigerator/freezer ice maker not working (Refrigerator & Freezer Repair)
by pauldw 10/19/2019 2:18:49 PM(UTC)
front of wall between refrigerator/freezer hot when unit has been off for 4 days (Refrigerator & Freezer Repair)
by Shreddder 12/7/2017 5:07:25 PM(UTC)
Refrigerator/Freezer Not Cooling (Refrigerator & Freezer Repair)
by sytipton 7/18/2017 12:39:26 PM(UTC)
Refrigerator/Freezer not getting to temp (Refrigerator & Freezer Repair)
by pape 11/29/2016 11:46:25 AM(UTC)
Whirlpool Refrigerator/Freezer not cooling Intermittenly (Refrigerator & Freezer Repair)
by mshilko 9/14/2016 9:33:30 AM(UTC)
Whirlpool Refrigerator/Freezer Lights Flicker (Refrigerator & Freezer Repair)
by Sarcastible 5/17/2016 7:34:34 AM(UTC)
Side by side refrigerator/freezer not cold (Refrigerator & Freezer Repair)
by jzannini 2/11/2016 11:59:48 AM(UTC)
Lights are on but frigerator/freezer doesn't cool (Refrigerator & Freezer Repair)
by Vaunt 11/11/2015 3:26:44 PM(UTC)
