| » Ge ice maker don't work water is fine |
Model Number: Pss27ngma Brand: GE Age: 1 - 5 years
Hello,
My GE ice maker stopped working, but the water is working fine. I took the ice maker out and took it apart. I fount a bad burn about the size of a quarter on the board opposite what looks to be the transformer. So I replaced the ice maker with a new one. still no ice. I checked the water line for ice and in seems ok. I'm thinking that my next step is to change the water valve an solenoid. There is no physical damage I can see. How can I test it. The serge was bad enough that it knocked out several GFIs and a small TV. Should the new ice maker have any sound or movement without water. I can't hear or see anything. Ads By Google Related Models |
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear. You can then see if the ice maker will freeze and dump the ice as it should.
| Display Modes | |
| Water dispenser does not work but Ice maker works fine | andreaj | Refrigerator & Freezer Repair | 0 | 12-03-2009 12:57 PM |
| Ice Maker working fine but no water | cweisg | Refrigerator & Freezer Repair | 1 | 11-17-2009 03:22 PM |
| Ice dispenser doesn't work on fridge, water works fine. | scirdan | Refrigerator & Freezer Repair | 0 | 10-23-2009 09:18 AM |
| Ice maker bad ,yet water fine | Chinchilla1 | Refrigerator & Freezer Repair | 1 | 05-26-2009 06:57 PM |
| ice maker doesn't work, water dispenses fine | frauhyde | Refrigerator & Freezer Repair | 0 | 01-10-2009 12:21 PM |
