firepatb
#1 Posted : Wednesday, May 27, 2009 4:29:02 AM(UTC)
firepatb
The compressor and fan never shut off, except for the defrost cycle, which is about every eight hours. The freezer is about 20 degrees set on the lowest setting. The refrigerator is about 35 degrees set on the middle
setting. The condenser coils are clean. The evaporater coils are free from
any "snow" or ice, except for some "snow" around the defrost thermomater which is fastend to the tube for the coils. Any idea's why the freezer can't get colder and always is running? Thanks, Pat
#2 Posted : Wednesday, May 27, 2009 5:09:05 PM(UTC)
Pat,
Looks like there is a problem with the sealed (cooling) system. It can be low on Freon or it can a restriction in the system. It has to be diagnosed by a certified tech.
Here are the breakdown diagrams and Replacement parts for AMANA BX22A5W | AppliancePartsPros.com
firepatb
#3 Posted : Thursday, May 28, 2009 3:48:05 AM(UTC)
firepatb
Thank You Gene, I appreciate your Help. I will call a Repairman to look at it. I think I checked everything I could with the help of this Forum, everything else appears to be working O.K. Thanks again.
Gene, one other thought. I was got this used, and it's been running for about 10 days. The freezer is empty, I've been waiting to see how it works before I put food in. Would this have any effect? Maybe it needs froozen food to help maintain the Temp? Also If I turn the Temp
control to a lower (warmer) setting, it stills runs constantly.
#4 Posted : Thursday, May 28, 2009 1:02:43 PM(UTC)
It does not need any frozen food to maintain the proper temperature. There is a problem with the refrigerator.
GE Refrigerator runs constantly (Refrigerator & Freezer Repair)
by crosby1 11/22/2013 7:07:48 AM(UTC)
refrigerator runs constantly-cold (Refrigerator & Freezer Repair)
by sidebyside 4/9/2008 10:00:40 AM(UTC)
